资料下载cascada BIO,AN实验室超纯水系统 This manual is provided to serve as the installation, operation, and maintenance guide for the Cascada Lab Water system models: Cascada BIO-water for biotechnology applications. Cascada AN-water for analytical applications.
PE Atomax1.5英寸空心阴极灯产品促销
简介:PE Atomax 空心阴极灯,适用于各品牌原子吸收光谱仪。 Atonmax 1.5”原子吸收空心阴极灯-来自原子吸收领域的全球领导者Perkinelmer 全新AtomaxTM1.5"空心阴极灯灯采用与业界领先的perkinelmer 2" LuminaTM空心阴极灯相同的高标准制造工艺。汲取了40多年的空心阴极灯设计制造经验,Atomax空心阴极灯可为全球各地实验室中的任何品牌的原子吸收光谱提供可靠的最高品质的光源。
pall现货促销产品
简介:盛世中方pall产品现货促销产品单,产品包括各种材质一次性针头滤器(GHP,PTFE,PVDF,尼龙,PES等),还有PALL可换膜滤器4020,不锈钢板式滤器平板滤器,47mm磁性过滤漏斗 300ml,25mm 可换膜针式过滤器,AcroCap 正压过滤器,pall各种过滤膜也是应有尽有
PALL 促销活动
简介:盛世中方为了答谢客户的支持,及更好的推广pall产品,现在正在举行pall产品的促销活动,活动包含了pall的各种常用物品,GHP,PVDF,PTFE,尼龙,supor膜各种材质的滤器,更有4020磁性密封流动相过滤器,详情请看附件,也可来电咨询。 此次活动只针对于终端顾客。
PALL Nanosep MF离心滤器
简介:PALL Nanosep MF离心滤器 Centrifugal devices are very simple to use. The sample to be processed is pipetted into the upper reservoir of the device. The device is placed into the appropriate centrifuge (taking care that the rotor is balanced) and spun. Filtrate can be recovered by removing the lower reservoir of the device and using a pipette or pipette tip to remove the liquid. Retentate can be recovered from the GHP Nanosep MF centrifugal device simply by pipetting it from the upper reservoir.
cascada RO
简介:cascada RO纯水系统 Foreword FOREWORD This manual is provided to serve as the installation, operation, and maintenance guide for the Cascada™ Lab Water system model: Part Number Description PAL-CAXXXROM2 Cascada RO-water System The manual should be read before attempting any cycle of installation, operation, and maintenance. If the instructions in this manual are not followed, the performance of this product and/or the safety of the user may be compromised. Unpack and inspect all items carefully to ensure they have not been damaged in transit. Service support and consumable items are available from your local Pall office or distributor. Refer to customer service contact information on back cover.
