资料下载Introduction Hybrid silphenylene backbone modied siloxane capillary GC stationary phases were commercially introduced two decades ago. These hybrid siloxanes demonstrated increased thermal stability over the conventional low polarity phases they were designed to mimic. The changes in physical properties induced by the insertion of rigid benzene ring bridges into the exible siloxane backbone also requires modications in surface chemistries to achieve good wettability and lm stability in order to maintain column eciency. Several years later, a second generation of more polar hybrid stationary phases was introduced. These polymers, designed to mimic 35% and 50% phenyl containing siloxanes, also often incorporated other types of aromatic backbone modications to further enhance thermal stability. Even more exotic surface chemistries were required to achieve wettablity while maintaining good deactivation. There are always trade-os and, in the end, deactivation often suered in the interest of column eciency. Recent application of new cross-bonding and deactivation chemistries to a 35% phenyl equivalent hybrid siloxane stationary phase has resulted in advances in both column eciency and inertness. These new columns display improved inertness for the analysis of highly polar compounds, producing symmetrical peaks for both basic and acidic compounds while maintaining high column eciencies.
Raptor C18柱分析全氟烷酸化合物,大大缩短EPA方法537分析时间
简介:Raptor C18 柱分析全氟烷酸化合物,可将你EPA 方法537 的分析时间缩短将近半个小时! 且在10分钟完整周期时间内具有极好的分离效果;可为很多应用,基质和化合物提供了极好的数据。
色谱柱使用和维护指南
简介:色谱柱的安装,色谱柱的储存,色谱柱的再生,MS 型色谱柱的老化,PLOT 色谱柱的安装和老化,故障排解,色谱柱退化的原因.
色谱柱选择指南
简介:气相色谱柱(以下简称色谱柱或柱子),是气相色谱(质谱)分析设备的心脏部件。选择一根适用的色谱柱不仅仅 能够对样品进行有效的分离,更是色谱分析结果准确性和可靠性的保证。如果使用了不合适的色谱柱产品,得到的是不 完全的分离结果和不准确的定性定量结果。 大约有10,000 种化合物可以用约400 种不同种类气相色谱柱进行分离。对于这样数量繁多的应用项目,色谱柱生产制 造厂家需要帮助用户选择到实际需要的产品。GS-TEK 通过多年的色谱柱制造和应用经验,可以快速地帮助您选择到合适 的色谱柱产品。
高比科技 LC-MS Ultra IB柱完美分离自来水阿莫西林 地表水抗生素
简介:阿莫西林在Ultra IBD柱完美分离,金霉素、强力霉素、四环素在Ultra C18柱上的完美分离,磺胺二甲基嘧啶 硫抗生素在Raptor Biphenyl柱上完美分离
高比科技-利用电子捕获检测器对含氯环境污染物进行分析
简介:讨论了在各种基质包括水、固体(土壤和植物材料)和生物(鱼和动物组织)中,监测含氯污染物的分析方法。化合物的类别,例如含氯农药、多氯联苯(PCBs)、含氯除草剂、消毒副产物以及熏蒸剂都是这里所提到的污染物。气相色谱仪与电子捕获检测器(ECD)联用是分析这些化合物的通用技术。ECD对带负电的化合物有很高的敏感度,因而具有极低的检测限。为了确保准确的鉴定结果,通过使用具有两个ECD的仪器和用于确认分析的具有不同选择性的两根色谱柱可以同时分析所有的样品。 极低的检测限与来样品基质的干扰结合在一起,成为实验室在含氯农药和除草剂分析上的一个挑战。样品常常会被非目标化合物例如脂类和烃类严重污染,而这个分析方法需要严格的质量控制方案。另外,有一些化合物在分析过程中会被破坏或者吸收,导致分析结果不准确。 本指导书提供了在提取、除杂以及对来自各种样品基质中的含氯农药、PCBs、消毒副产物和熏蒸剂的GC分析上的信息。还包括一些可以简化这些化合物分析的产品的列表。
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
