进口动物呼吸机技术参数详解 -2
2014-09-23 14:21  下载量:1
资料下载
BS4 55-0000 BS4 55-0798, BS4 55-0806 BS4 55-0715 BS4 55-7059 Small Animal 683 Intermediate Animal 665 Large Animal 613 Inspira Multi-Channel Ventilator KTR-4 VOLUME VENTILATORS PRESSURE VENTILATORS rats, guinea pigs, rabbits, cats, dog rats, guinea pigs, mice, rats, guinea pigs, rats, guinea pigs rats, guinea pigs, rabbits rabbits, cats cats, dogs rabbits, cats 250 g to 10 kg (22 lbs) 1 kg (2.2 lbs) to 1.5 kg (3.3 lbs) to 15 g to 10 kg 150 g to 1 kg 150 g to 5.5 kg 30 kg (66 lbs) 50 kg (110 lbs) 0.5 to 5 ml 4 to 100 ml 30 to 750 ml NOT AVAILABLE NOT AVAILABLE NOT AVAILABLE 3 to 30 ml 18 to 150 10 to 200 7 to 50 5 to 200 30 to 100 1 to 199 CE CE, EMC CE CE CE CE 1:1 35% to 65% of a 25% to 50% of a 1:4 to 4:1 10% to 80% of a 1 to 99% single stroke cycle single stroke cycle single stroke cycle NO NO NO NO Up to eight simultaneously NO with individual volumes NO NO NO NO yes 4 (58 lbs) to 8 bar (116) NO NOT AVAILABLE NOT AVAILABLE NOT AVAILABLE 0 to 50 cmH2O NOT AVAILABLE NO NO NO 5 to 12 V peak pulse NO NO NO NO NO 0 to 50 cmH2O NO NO NO NO NO auto or manual NO NO NO NO NO YES NO NO NO NO NO YES NO NO - - - YES NO NO NO NO NO YES 100 cmH2O NO NO NO NO YES 2 to 100 cmH2O NO yes (attach yes (attach yes (attach built in yes (attach column of water) yes (attach column of water) column of water) column of water) column of water) NO NO NO YES NO NO OD 5 mm (3/16 in), OD 7.9 mm, ID 6.4 mm OD 15.9 mm, ID 12.7 mm ID 3.5 mm (1/8 in) 25 x 32.5 x 15 cm 35 x 20 x 45 cm 30 x 50 x 22.5 cm 17.8 x 25.4 x 40.6 cm 36 x 15 x 34 cm (10 x 13 x 6 in) (14 x 8 x 18 in) (12 x 20 x9 in) (8 x 10 x 17.25 in) (14.2 x 5.9 x 13.4 in) F7 F12 F13 F4 F9 F10
资料下载
文献贡献者
相关资料 更多
当前位置: 香港友诚 资料 进口动物呼吸机技术参数详解 -2
