注射泵PHD 22/2000 HPSI
2014-09-24 11:22  下载量:2
资料下载
PHD 22/2000 Hpsi Specifications TYPE Microprocessor multiple syringe, infusion/withdrawal programmable ACCURACY ±0.5% REPRODUCIBILITY ±0.05% SYRINGES (MIN/MAX) Holds 20 to 200 ml stainless steel syringes FLOW RATE: Minimum 1.5 μl/hr Maximum 112 ml/min RS-232 RJ11-4 conductor TTL 9-pin D-Sub Connector AVERAGE LINEAR FORCE 197 kg (433 lbs) STEP RESOLUTION 0.0794 μm/μstep VOLTAGE RANGE Universal input 100/240 VAC, 50/60 Hz CABLE LENGTH 152 cm (5 ft) approx. DIMENSIONS, H x W x D: Control Box 9.5 x 27.9 x 22.9 cm (3.75 x 11 x 9 in) Syringe Holder 22.9 x 43.2 x 30.5 cm (9 x 17 x 12 in)
资料下载
文献贡献者
相关资料 更多
当前位置: 上海抚生 资料 注射泵PHD 22/2000 HPSI
