方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 |
Instech’s clear animal enclosures are ideal for tethered rodents, as they have no sharp corners where the tether can catch or tangle. Originally designed for short-term microdialysis experiments, the tanks can be ordered pre-machined to accommodate feeders and water bottles in order to house animals for longer periods. The floor areas of the two models exceed USDA regulations and NRC guidelines for the largest singly-housed rats and mice.1 The feeders and water bottles mount outside the tank to avoid interference with the tether. The feeder pellet opening is approximately 13x20mm. Use the 6-inch MCLA lever arm with the larger rat tank and the 3.5-inch SMCLA arm with the small mouse tank
利用四倍体胚胎补偿法制备 ES 小鼠的技术方法
荧光定量PCR应用领域
不经显微操作进行体细胞克隆(徒手克隆)
