产品名称: 大鼠γ干扰素(IFN-γ)ELISA Kit
英文名称: Rat Interferon γ ,IFN-γ ELISA Kit
别名: IFG, IFI
货号: CSB-E04579r
价格: 3900
规格: 96T
种属: Rat
待测物名称: interferon, gamma
缩写: IFNG
样本类型: serum, plasma and tissue homogenates
检测范围: 0.625 pg/ml-40 pg/ml
灵敏度: 0.156 pg/ml
反应时间: 1-5h
所需样本体积: 50-100ul
检测波长: 450 nm
用途: For research use only. Not for diagnostic use.
原理 : This assay employs the quantitative sandwich enzyme immunoassay technique. Antibody specific for IFNG has been pre-coated onto a microplate. Standards and samples are pipetted into the wells and any IFNG present is bound by the immobilized antibody. After removing any unbound substances, a biotin-conjugated antibody specific for IFNG is added to the wells. After washing, avidin conjugated Horseradish Peroxidase (HRP) is added to the wells. Following a wash to remove any unbound avidin-enzyme reagent, a substrate solution is added to the wells and color develops in proportion to the amount of IFNG bound in the initial step. The color development is stopped and the intensity of the color is measured.
特异性: This assay has high sensitivity and excellent specificity for detection of Rat IFNG. No significant cross-reactivity or interference between Rat IFNG and analogues was observed.
精密度: Intra-assay Precision (Precision within an assay): CV%<8%
Three samples of known concentration were tested twenty times on one plate to assess.
Inter-assay Precision (Precision between assays): CV%<10%
Three samples of known concentration were tested in twenty assays to assess.
样本搜集及储存: Serum: Use a serum separator tube (SST) and allow samples to clot for two hours at room temperature or overnight at 4°C before centrifugation for 15 minutes at 1000 ×g. Remove serum and assay immediately or aliquot and store samples at -20°C or -80°C. Avoid repeated freeze-thaw cycles.
Plasma: Collect plasma using EDTA, or heparin as an anticoagulant. Centrifuge for 15 minutes at 1000 ×g at 2-8°C within 30 minutes of collection. Assay immediately or aliquot and store samples at -20°C or -80°C. Avoid repeated freeze-thaw cycles.
检测步骤: Bring all reagents and samples to room temperature before use. Centrifuge the sample again after thawing before the assay. It is recommended that all samples and standards be assayed in duplicate.
1. Prepare all reagents, working standards, and samples as directed in the previous sections.
2. Refer to the Assay Layout Sheet to determine the number of wells to be used and put any remaining wells and the desiccant back into the pouch and seal the ziploc, store unused wells at 4°C.
3. Add 100μl of standard and sample per well. Cover with the adhesive strip provided. Incubate for 2 hours at 37°C. A plate layout is provided to record standards and samples assayed.
4. Remove the liquid of each well, don't wash.
5. Add 100μl of Biotin-antibody (1x) to each well. Cover with a new adhesive strip. Incubate for 1 hour at 37°C. (Biotin-antibody (1x) may appear cloudy. Warm up to room temperature and mix gently until solution appears uniform.)
6. Aspirate each well and wash, repeating the process two times for a total of three washes. Wash by filling each well with Wash Buffer (200μl) using a squirt bottle, multi-channel pipette, manifold dispenser, or autowasher, and let it stand for 2 minutes, complete removal of liquid at each step is essential to good performance. After the last wash, remove any remaining wash Buffer by aspirating ordecanting. Invert the plate and blot it against clean paper towels.
7. Add 100μl of HRP-avidin (1x) to each well. Cover the microtiter plate with a new adhesive strip. Incubate for 1 hour at 37°C.
8. Repeat the aspiration/wash process for five times as in step 6.
9. Add 90μl of TMB Substrate to each well. Incubate for 15-30 minutes at 37°C. Protect from light.
10. Add 50μl of Stop Solution to each well, gently tap the plate to ensure thorough mixing.
11. Determine the optical density of each well within 5 minutes, using a microplate reader set to 450 nm. If wavelength correction is available, set to 540 nm or 570 nm. Subtract readings at 540 nm or 570 nm from the readings at 450 nm. This subtraction will correct for optical imperfections in the plate. Readings made directly at 450 nm without correction may be higher and less accurate.
结果计算: Using the professional soft "Curve Expert 1.3" to make a standard curve is recommended, which can be downloaded from our web.
Average the duplicate readings for each standard and sample and subtract the average zero standard optical density.
Create a standard curve by reducing the data using computer software capable of generating a four parameter logistic (4-PL) curve-fit. As an alternative, construct a standard curve by plotting the mean absorbance for each standard on the x-axis against the concentration on the y-axis and draw a best fit curve through the points on the graph. The data may be linearized by plotting the log of the IFNG concentrations versus the log of the O.D. and the best fit line can be determined by regression analysis. This procedure will produce an adequate but less precise fit of the data.
If samples have been diluted, the concentration read from the standard curve must be multiplied by the dilution factor.
相关产品:
产品名称 英文名称 货号 规格
山羊γ干扰素(IFN-γ)ELISA Kit Goat Interferon γ ,IFN-γ ELISA Kit CSB-E12966G 96T
仓鼠γ干扰素(IFNG)ELISA kit Hamster interferon, gamma (IFNG) ELISA kit CSB-EL011050HA 96T
猪γ干扰素(IFN-γ)ELISA Kit Pig Interferon γ ,IFN-γ ELISA Kit CSB-E06794p 96T
牛γ干扰素(IFN-γ)ELISA Kit Bovine Interferon γ ,IFN-γ ELISA Kit CSB-E09812b 96T
鸭γ干扰素(IFNG) ELISA kit Duck interferon, gamma (IFNG) ELISA kit CSB-EL011050DU 96T
鱼γ干扰素(IFN-γ)ELISA Kit Fish Interferon γ ,IFN-γ ELISA Kit CSB-E12878Fh 96T
绵羊γ干扰素(IFN-γ)ELISA Kit Sheep Interferon γ ,IFN-γ ELISA Kit CSB-E14018Sh 96T
人γ干扰素(IFN-γ)ELISA Kit Human Interferon γ ,IFN-γ ELISA Kit CSB-E04577h 96T
小鼠γ干扰素(IFN-γ)ELISA Kit Mouse Interferon γ ,IFN-γ ELISA Kit CSB-E04578m 96T
兔子γ干扰素(IFN-γ)ELISA Kit rabbit Interferon γ ,IFN-γ ELISA Kit CSB-E06925Rb 96T
鸡γ干扰素(IFN-γ)ELISA Kit Chicken Interferon γ ,IFN-γ ELISA Kit CSB-E08550Ch 96T
鹿γ干扰素(IFNG) ELISA kit Deer interferon, gamma (IFNG) ELISA kit CSB-EL011050DE 96T
猴γ干扰素(IFN-γ)ELISA Kit Monkey Interferon γ ,IFN-γ ELISA Kit CSB-E10049Mo 96T
Horse Interferon gamma(IFNG) ELISA kit Horse Interferon gamma(IFNG) ELISA kit CSB-EL011050HO 96T
Donkey Interferon gamma(IFNG) ELISA kit Donkey Interferon gamma(IFNG) ELISA kit CSB-EL011050DK 96T
犬γ干扰素(IFN-γ)ELISA Kit Dog Interferon γ ,IFN-γ ELISA Kit CSB-E11262c 96T
Cat Interferon gamma(IFNG) ELISA kit Cat Interferon gamma(IFNG) ELISA kit CSB-EL011050CA 96T
抗体
产品名称 货号 规格
Rabbit anti-human interferon, gamma polyclonal Antibody CSB-PA011050GA01HU 150ul
蛋白
产品名称 货号 规格 蛋白来源
Recombinant Meleagris gallopavo Interferon gamma(IFNG) 1mg
Recombinant Coturnix coturnix japonica Interferon gamma(IFNG) 1mg
Recombinant Numida meleagris Interferon gamma(IFNG) 1mg
Recombinant Phasianus colchicus colchicus Interferon gamma(IFNG) 1mg
Recombinant Marmota monax Interferon gamma(IFNG) 1mg
Recombinant Mesocricetus auratus Interferon gamma(IFNG) 1mg
Recombinant Mustela putorius furo Interferon gamma(IFNG) 1mg
Recombinant Rat Interferon gamma(Ifng) 1mg
Recombinant Macaca nemestrina Interferon gamma(IFNG) 1mg
Recombinant Macaca fascicularis Interferon gamma(IFNG) 1mg
Recombinant Callithrix jacchus Interferon gamma(IFNG) 1mg
Recombinant Cercocebus atys Interferon gamma(IFNG) 1mg
Recombinant Cervus elaphus Interferon gamma(IFNG) 1mg
Recombinant Donkey Interferon gamma(IFNG) 1mg
Recombinant Mouse Interferon gamma(Ifng) 1mg
Recombinant Bovine Interferon gamma(IFNG) 1mg
Recombinant Human Interferon gamma(IFNG) 1mg
Recombinant Macaca mulatta (Rhesus macaque) Interferon gamma(IFNG) 1mg
Recombinant Chicken Interferon gamma(IFNG) 1mg
Recombinant Cat Interferon gamma(IFNG) 1mg
Recombinant Horse Interferon gamma(IFNG) 1mg
Recombinant Dog Interferon gamma(IFNG) 1mg
Recombinant Rabbit Interferon gamma(IFNG) 1mg
Recombinant Pig Interferon gamma(IFNG) 1mg
Recombinant Sheep Interferon gamma(IFNG) 1mg
Recombinant Goat Interferon gamma(IFNG) 1mg
CUSABIO开学巨献 购ELISA kit享好礼
上海希美提供全基因合成服务
上海希美提供RT-PCR服务
上海希美提供杆状病毒-昆虫细胞表达与纯化
重组人肌球蛋白轻链2(Recombinant Human MYL2)
重组大鼠抵抗素(Rat Resistin)
3-D Life Dextran-PEG Hydrogel Kit
3-D Life Dextran-CD Hydrogel Kit(3D 细胞培养 葡聚糖马来酰亚胺-聚乙二醇仿生水凝胶试剂盒)
3-D水凝胶PEG-Link(聚乙二醇交联剂)(3D细胞培养 PEG 交联物(非降解))
3-D Life CD-Link(3D细胞培养 CD 交联物(可细胞降解))
3-D Life Maleimide-Dextran Set(3D 细胞培养葡聚糖马来酰亚胺聚合物)
3D 细胞培养RGD多肽(粘附剂)3-D Life RGD Peptide
3-D Life Scrambled RGD Peptide
Pig C-type lectin domain family 5 member A(CLEC5A)ELISA kit
Mouse C-type lectin domain family 5 member A(CLEC5A)ELISA kit
Human C-type lectin domain family 5 member A(CLEC5A)ELISA kit
无形体IgM免疫荧光试剂盒
牛甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
鸡甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
