资料下载The Global Water Flow Probe is a highly accurate water velocity instrument for measuring flows in open channels and partially filled pipes. The water velocity probe consists of a protected water turbo prop positive displacement sensor coupled with an expandable probe handle ending in a digital readout display. The water flow meter incorporates true velocity averaging for the most accurate flow measurements. The Flow Probe is ideal for storm water runoff studies, sewer flow measurements, measuring flows in rivers and streams, and monitoring velocity in ditches and canals.
RainWise产品目录
简介:RainWise公司的所有产品分类目录,详尽的介绍了RainWise公司的各种产品的名称、功用和性能指标。
WS700 便携式水质采样器
简介: WS700单瓶混合/离散水质采样器适用于各种水质采样要求,如雨水、工业排放废水、用水和废水处理、废水收集系统及江河水等。
WL400 产品简介
简介:Global Water's WL400 Water Level Sensor submersible pressure transducer consists of a solid state pressure sensor encapsulated in a submersible stainless steel 13/16!± diameter housing. The water level gauge uses a marine grade cable to connect the water pressure sensor to the monitoring device. Each of Global Water's pressure transducers has a two-wire 4-20 mA high level output, five full scales ranges, and is fully temperature and barometric pressure compensated.
YSI556 产品简介
简介:Rugged and reliable, the YSI 556 MPS combines the versatility of an easy-to-use, easy-to-read handheld unit with all the function of a multiparameter system.
