资料下载ASTM E21-05金属材料高温拉伸试验方法 Standard Test Methods for Elevated Temperature Tension Tests of Metallic Materials1 This standard is issued under the fixed designation E 21; the number immediately following the designation indicates the year of original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A superscript epsilon (e) indicates an editorial change since the last revision or reapproval. This standard has been approved for use by agencies of the Department of Defense. 1. Scope 1.1 These test methods cover procedure and equipment for the determination of tensile strength, yield strength, elongation, and reduction of area of metallic materials at elevated temperatures. 1.2 Determination of modulus of elasticity and proportional limit are not included. 1.3 Tension tests under conditions of rapid heating or rapid strain rates are not included. 1.4 The values stated in SI units are to be regarded as the standard. 1.5 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
GB/T 36276-2023 电力储能用锂离子电池
简介:GB/T 36276-2023 电力储能用锂离子电池 Lithium ion battery for electrical energy storage 代替GB/T 36276—2018
GB 42295-2022电动自行车电气安全要求
简介:GB 42295-2022电动自行车电气安全要求 Safety requirement for electric bicycles electrical
GB 42295-2022 电动自行车电气安全要求
简介:GB 42295-2022 电动自行车电气安全要求 Safety requirement for electric bicycles electrical
电动汽车用动力蓄电池安全要求GB 38031-2020
简介:电动汽车用动力蓄电池安全要求GB 38031-2020代替GB/T 31485—2015,GB/T 31467.3—2015
GB8410-2006汽车内饰材料燃烧特性
简介:GB8410-2006汽车内饰材料燃烧特性
拉力试验机/万能材料试验机 PW-US70 越联PW
节能款恒温恒湿箱PW-CTH100-40 越联PW
高低温拉力机PW-UCS80-40越联PW
双柱拉力机 拉力试验机PW-UD20 越联PW
泡棉压缩电阻测试仪PW-FCR2-2越联PW
落球冲击吸能试验机PW-IR500/PW-IR1000越联PW
三箱冷热冲击试验箱,二箱冷热冲击试验机,三箱冷热冲击
撕膜电压试验机PW-UPV01 越联PW
高温90度保持力试验机PW-HP60T2-90S 越联PW
摩擦系数试验机PW-1103F 越联PW
YL-S90剥离强度试验机
越联YL-S70离型膜剥离力试验机
越联YL-D23伺服橡胶压力试验机
德国三维扫描仪 3D Scanner Supplier
高低温湿热试验箱 越联造
