资料下载Made in Shanghai, China Factory outlets Competitive price Beautiful, durable products Good vacuum and temperature Vacuum drying oven is widely applicable for drying and sterilization in fields of biochemistry, pharmacy, medicine and health, agriculture and scientific research and environment protection. It is designed specially for drying of material which is thermo-sensitive or decompounded and oxidative easily. It has follow advantages compare with the routine dry technology: Vacuum environment greatly reduced the liquid boiling point which needs to drive out, therefore the vacuum dry method is applicable for heat sensitivity material; For the sample that can't be dried easily, such as powder or other pellet form sample, using vacuum dry method may efficiently shorten dry time; Various complex structures of machinery ministry or other porous sample process are used of vacuum dry method after washing, and Completely dry without leaving any residue; Use more safe: under vacuum or inertia condition, completely eliminate the possibility that the oxide heated and explode; 上海和呈仪器制造有限公司Shanghai Hasuc Instrument Manufacture Co.,Ltd http://www.hasuc.cn http://www.hasuc.cc http://www.shlab17.com http://www.4008806667.com http://www.shhasuc.com http://www.dryexpo.com http://www.5911718.com 办公地址:上海市奉贤区南桥镇翡翠国际广场1号楼1020 工厂地址:上海浦卫公路6955号 总机电话:021-51688813 直线电话:021-67186861/57188687 /60457408 /60457409 总机传真:021-51686613 直线传真:021-57188687-806 自动传真:021-51686613 人工传真:021-57188687-806 企业QQ:400-880-6667 Compare with the normal drying depended on air cycle, Powder samples will not be blown or moved by air
电热恒温干燥箱工作原理?
简介:电热恒温干燥箱工作原理? 电热恒温干燥箱最高工作温度为300℃(需特种高温可定做),可供各种试品置入使用。它适用于烘焙、干燥、热处理及其他加热。工业上式试验室都可使用(但不能将带挥发物的物品置入干燥箱,以免引起爆炸)。 干燥箱之工作温度可由室温升起至最高温度止,在此范围内可注意选定工作温度,选定后可借箱内自动控制系统使电热恒温干燥箱。 202型干燥箱工作室内借冷热空气之比重动向促成对流,使室内温度更加均匀。 101型干燥箱工作室内装有鼓风机,促成机械空气对流。 电热恒温干燥箱结构精密,控温灵敏准确,操作简便,工厂及科学研究单位等均可采用。 结构说明 电热恒温干燥箱由簿钢板制成,箱体内有一供放置试品的工作室,工作室内有试品搁板,试品可置于其上进行干燥,如遇试品较大,可抽去搁板,工作室与箱体外壳间有相当厚度的保温层中以硅棉或珍珠岩作保温材料,箱门间有一玻璃门或观察口,以供观察工作内之情况。 此电热恒温干燥箱用先进的TEA仪表自动调节。热电偶伸入工作室,感应灵敏。控制器、电热器之全部电气操纵设备均用仪表控制,控制室有侧门可以卸下,以备检查或修理线路时用。 电热器装于箱体内工作室下,共分二组,即“高温和低温”,并有指示灯指示,绿灯亮表示电热器工作,箱内在加热,红灯灭表示加热停止。
操作真空干燥箱的正确步骤是什么?
简介:操作真空干燥箱的正确步骤1.需干燥处理的物品放入真空干燥箱内,将箱门关上,并关闭放气阀,开启真空阀,接通真空泵电源开始抽气,使箱内真空度达到-0.1mpa时,关闭真空阀,再关闭真空泵电源。2.把真空干燥箱电源开关拨至“开”处,选择所需的设定温度,箱内温度开始上升,当箱内温度接近设定温度时,加热指示灯忽亮忽熄,反复多次,一般120min以内可进入恒温状态。3.当所需工作温度较低时,可采用二次设定方法,如所需温度60℃,第一次可设定50℃,等温度过冲开始回落后,再第二次设定60℃。这样可降低甚至杜绝温度过冲现象,尽快进入恒温状态。4.根据不同物品潮湿程度,选择不同的干燥时间,如干燥时间较长,真空度下降,需再次抽气恢复真空度,应先开真空泵电源,再开启真空阀。5.干燥结束后应先关闭干燥箱电源,开启放气阀,解除箱内真空状态,再打开箱门取出物品。(解除真空后,如密封圈与玻璃门吸紧变形不易立即打开箱门,经过一段时间后,等密封圈恢复原形后,才能方便开启箱门
恒温培养箱的分类有哪些?
简介:恒温培养箱分为十类: 1、电热恒温培养箱 2、生化培养箱 3、霉菌培养箱 4、隔水式培养箱 5、恒温恒湿箱 6、光照培养箱 7、人工气候箱 8、二氧化碳培养箱 9、振荡培养箱 10、孵化箱
一次性口罩如何正确重复使用?
简介:中国院士:研究证明,一次性医学口罩使用后,用干燥箱处理30分钟后,病毒几乎完全被灭活,与没有病毒的对照标本相当。可以再生,不影响其原有的功能。据了解,研究团队应用热处理技术中最普遍应用的恒温烘箱及电热吹风对口罩进行处理后,检测其病毒灭活效果及滤过截留功能,以截留PM 2.5作为检测处理后的滤过截留指标。在病毒实验中,他们用活流感病毒模拟冠状病毒,在安全实验室内,将细胞培养的病毒定量后滴在口罩上,人工造成污染。经用烘箱或热电吹风处理后,再取口罩表面的病毒进行细胞培养,观察病毒引起的细胞病变及定量检验病毒核酸。结果显示,烘箱56℃及热电吹风30分钟后,对口罩的滤过截留功能均无显著影响;经热吹风30分钟后,病毒几乎完全被灭活,与没有病毒的对照标本相当。而烘箱56℃30分钟,由于标本外包有锡盒,未能完全灭活病毒。 ?因此,研究证明:一次性医学口罩使用后,用电热吹风处理30分钟后可以再生,不影响其原有的功能。
详细讲解:高温试验箱与电热鼓风干燥箱的区别有哪些?
简介:详细讲解:高温试验箱与电热鼓风干燥箱的区别有哪些? 下面是我司为您讲解下高温试验箱与电热鼓风干燥箱的区别有哪些? 1、高温试验箱和电热鼓风干燥箱的用途不同:两者都是工作空间温度高于室温至某一特定温度的试验箱。但高温试验箱一般用于精密试样的高温老化或者干燥,样品的含浸不能太大,温度控制的精度比较高;而电热鼓风干燥箱多用于水分含量比较多的样品的烘干,设备带有可以调节大小的排湿管,一般对控温精度要求不是很严格。 2、高温试验箱和电热鼓风干燥箱的结构特点不同:高温试验箱具有独立的循环风道设计,加热后的热空气在特定的风道中循环,有出风口和回风口,能够保证箱内的温度均匀度;电热鼓风干燥箱的循环只是通过风机将热空气直接吹向箱内,箱内的温度均匀度不高。 高温试验箱都带有测试用的引线孔,可以外接电源或仪器。 3、高温试验箱和电热鼓风干燥箱的控制器不同;高温试验箱采用进口温度控制器,具有较宽的温度试验范围,用pt100铂电阻作传感器,温度控制灵敏度高,温度均匀性好,具有漏电保护、超温报警、超温保护功能。而电热鼓风干燥箱一般不能具备这些特点。 4、高温试验箱和电热鼓风干燥箱的主要技术指标不同:高温试验箱的技术参数:温度范围:室温+10℃~500℃温度均匀度:±2℃温度波动度:±0.5℃控温精度:0.1℃升温速率:1~3℃/min电热鼓风干燥箱是航空、汽车、家电、实验室、科研等领域必备的测试设备,用于测试和确定电工、电子及其他产品及材料进行高温试验的温度环境变化后的参数及性能。电热鼓风干燥箱的技术参数:温度范围:rt+10℃~200℃(250℃)控制精度:±1%(满量程)恒温波动度:±1℃温度分辨率:0.1℃
HASUC 锂电池 电容 真空烘箱
HASUC 洁净烘箱 BPG-9000CH
HASUC 氮气干燥箱 101-2
HASUC 锂电电池 真空烘箱 HSFBZK1500L
HASUC恒温干燥箱 DHG-*9035A
HASUC 干燥箱 鼓风机烘箱 dhg-9240(A)
HASUC 鼓风干燥箱 烘箱 dhg-9425A
HASUC恒温鼓风干燥箱 DHG-/9425A
HASUC 干燥箱 DHG-9420A
HASUC 电热干燥箱 烘箱 DHG-9055A
HASUC 干燥箱 烘干机 热老化箱 DHG-9055A
恒温恒湿箱 恒温恒湿机 HS-50B
HASUC 鼓风干燥箱 DHG--9420A
HASUC上海精密干燥箱 DHG BPJ
HASUC 电子产品测试箱 恒温恒湿箱 HS-50B
