资料下载对于抗生素类兽药残留的检测,其他氨基糖苷类的检测,用到CBX小柱(500mg/6ml)7217-06进行样品前处理,之后通过LC/MS检测,得到了良好的分析效果。 Rapid screening tests can be used as part of an efficient program designed to monitor veterinary drug residues in cattle. In this work, three rapid tests designed to screen samples for the presence of antibiotic residues, the Fast Antimicrobial Screen Test (FAST), Premi® and Kidney InhibitionSwab (KISTM) tests,were compared using beef kidney juice and serum samples. In order to provide a realistic assessment, potentially incurred samples of beef kidney juice and serum were obtained from 235 carcasses which had been retained by inspectors in a processing plant for further testing. In addition, liquid chromatography–tandem mass spectrometry (LC–MS/MS) analysis was conducted on these samples to identify what antibiotics were present, if any, and their levels. The comparison of the three rapid screening test results with those from LC–MS/MS analysis allowed for a more complete comparison of the relative sensitivity of these analytical methods, as well as valuable information on false positive and negative response rates. Published by Elsevier B.V.
Avantor 药用辅料及实验室化学品目录
简介:专业化学,提升你的功效 AVANTOR拥有全球实验室、研发中心和化学工业所期 望的化学品质,并激发不断创新的动力。我们的化学 品质在产品质量和可重现性方面一直处于领先地位。 在当今仪器更加先进、试样量更少更精密的时代,我 们使客户在市场上处于有利地位,并始终致力于追求 近乎完美的再现性和一致性。从研发到大规模生产过 程,我们专业化、应用不断优化的产品在纯度高要求 的场合一直被广泛使用。 前言 3–9 药用辅料 10–35 生物制药辅料 14–20 化学制药辅料 21–35 高纯溶剂 36–53 样品处理 54–71 元素分析试剂 72–81 J.T.Baker?HYDRA-POINT? 82–87 卡尔费休试剂 J.T.Baker?和 Macron? 88–93 滴定标准溶液和试剂 药典标准检测 94–101 超纯生物试剂 102–109 实验室安全和清洗产品 110–118
J.T.Baker 快速多农残分析方案—— QuEChERs分散SPE
简介:J.T.Baker分散SPE产品 --适用于QuEChERs方法 AVANTOR旗下J.T.Baker品牌最新推出分散SPE产品,专为QuEChERs快速多农残分析方法而设计,为QuEChERs分析的每一步提供可靠一致的检测结果。 J.T.Baker品牌BAKERBOND QuEChERs方法分散SPE产品推出的混合担体,适用于15ml离心管。针对于不同种类样品,其离心管的盖子色标也不同,便于快速识别;管中已装填了按比例预混好的盐,以节省时间并提高样品制备的效率。BAKERBOND 分散SPE产品在ISO规范下生产,既适用于欧盟标准(EN15662),也满足美国分析协会规范(AOAC2007.01)。
J.T.Baker?和Macron? 实验室化学品目录
简介:专业化学,提升你的功效 AVANTOR拥有全球实验室、研发中心和化学工业所期 望的化学品质,并激发不断创新的动力。我们的化学 品质在产品质量和可重现性方面一直处于领先地位。 在当今仪器更加先进、试样量更少更精密的时代,我 们使客户在市场上处于有利地位,并始终致力于追求 近乎完美的再现性和一致性。从研发到大规模生产过 程,我们专业化、应用不断优化的产品在纯度高要求 的场合一直被广泛使用。 前言 3–9 高纯溶剂 10-27 样品处理 28-45 元素分析试剂 46-55 J.T.Baker?HYDRA-POINT? 56-61 卡尔费休试剂 J.T.Baker?和 Macron? 62-67 滴定标准溶液和试剂 药典标准检测 68-75 超纯生物试剂 76-83 实验室安全和清洗产品 84-92
J.T.Baker GC-HS 顶空气相色谱试剂
简介:J.T.Baker GC-HS顶空气相色谱试剂 AVANTOR公司扩展了其针对制药市场应用的高纯溶剂产品线。作为J.T.BAKER品牌旗下产品, 新溶剂专为更灵敏的顶空气相色谱分析而开发,检测挥发性有机杂质。溶剂的纯度和参数特性满足欧洲药典(2.4.24章)和美国药典(467章)的要求以及国际协调会议(ICH)的规范。每个溶剂都经过应用优化和功能性测试以保证最优化的性能。
MACRON色谱溶剂专刊
简介:MACRON品牌ChromAR级别溶剂 是分析检测的理想选择,广泛应用于不同行业和领域, 满足批次一致性和品质可靠性的要求。这些溶剂产品 在严格的规范下生产,让你在各种液相色谱应用中都 得到满意可靠的分析结果。
