方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In chiral chromatography, the technology of detecting chiral molecules using optical devices has lagged behind until now. The stability and sensitivity of this type of instrument is an important issue in chiral chromatography. with the availability of the single wavelength LED, increased sensitivity and increased economics with simplified instrument design was possible. a newly designed glass coated steel flow cell has produced a superior, third generation optical rotation detector. Aided with the Faraday compensation technique, this instrument gives high optical rotation power with excellent signal to noise ratio. ……
扩散波谱仪在乳液中的应用
四种手性检测器对比
