又便宜又质量有保证的小鼠粒-巨噬细胞集落刺激因子/GM CSF Mouse 重组小鼠粒-巨噬细胞集落刺激因子/GM CSF Mouse
SynonymsCSF-2, MGI-1GM, GM-CSF, Pluripoietin-alpha, Molgramostin, Sargramostim.IntroductionGMCSF is a cytokine that controls the production, differentiation, and function of granulocytes and macrophages. The active form of the protein is found extracellularly as a homodimer. This gene has been localized to a cluster of related genes at chromosome region 5q31, which is known to be associated with interstitial deletions in the 5q- syndrome and acute myelogenous leukemia. Other genes in the cluster include those encoding interleukins 4, 5, and 13.
GM-CSF stimulates the growth and differentiation of hematopoietic precursor cells from various lineages, including granulocytes, macrophages, eosinophils and erythrocytes.DescriptionGranulocyte Macrophage Colony Stimulating Factor Mouse Recombinant produced in E.Coli is a single, non-glycosylated, polypeptide chain containing 125 amino acids and having a molecular mass of 14285.35 Dalton.
GM-CSF Mouse is purified by proprietary chromatographic techniques.SourceEscherichia Coli.Physical AppearanceSterile Filtered White lyophilized (freeze-dried) powder.FormulationGM-CSF Mouse was lyophilized with no additives.SolubilityIt is recommended to reconstitute the lyophilized Granulocyte Macrophage Colony Stimulating Factor in sterile 20mM AcOH (acetic Acid) not less than 100μg/ml, which can then be further diluted to other aqueous solutions.StabilityLyophilized Granulocyte Macrophage Colony Stimulating Factor although stable at room temperature for 3 weeks, should be stored desiccated below -18°C. Upon reconstitution GM-CSF should be stored at 4°C between 2-7 days and for future use below -18°C.
For long term storage it is recommended to add a carrier protein (0.1% HSA or BSA).
Please prevent freeze-thaw cycles.PurityGreater than 98.0% as determined by(a) Analysis by RP-HPLC.
(b) Analysis by SDS-PAGE.Amino acid sequenceThe sequence of the first five N-terminal amino acids was determined and was found to be Met-Ala-Pro-Thr-Arg.Biological ActivityThe ED50 as determined by the dose-dependant stimulation of the proliferation of murine FDC-P1 cell line is < 0.2 ng/ml, corresponding to a Specific Activity of 5,000,000 IU/mg.Protein contentGM-CSF quantitation was carried out by two independent methods
1. UV spectroscopy at 280 nm using the absorbency value of 0.765 as the extinction coefficient for a 0.1% (1mg/ml) solution. This value is calculated by the PC GENE computer analysis program of protein sequences (IntelliGenetics).
2. Analysis by RP-HPLC, using a calibrated solution of GM-CSF as a Reference Standard.References1.Title:Multigene/multisubtype HIV-1 vaccine induces potent cellular and humoral immune responses by needle-free intradermal delivery.
Publication: Mol Ther. 2005 Dec;12(6):1197-205. Epub 2005 Aug 22. Pmid: 16112909
Link: http://www.nature.com/mt/journal/v12/n6/full/mt20051405a.html
Applications: The Mouse GM-CSF used for 2 purposes:
1. As an adjuvant for DNA vaccine which included seven plasmids encoding nine HIV-1 proteins. The mice were injected with the DNA vaccine together with recombinant mouse GM-CSF. 2. Used in Elisa.
2.Title: Neospora caninum: cloning and expression of a gene coding for cytokine-inducing profilin.
Publication: Exp Parasitol. 2010 Aug;125(4):357-62. Epub 2010 Mar 6. Pmid: 20211619
Link: http://www.sciencedirect.com/science/article/pii/S001448941000086X
Applications: Used for immunoblotting
3.Title: Intranasal Granulocyte-Macrophage Colony-Stimulating Factor Reduces the AspergillusBurden in an Immunosuppressed Murine Model of Pulmonary Aspergillosis.
Publication: Antimicrob Agents Chemother. 2008 February; 52(2): 716–718.
Published online 2007 November 5
Link: http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2224773/?tool=pmcentrez
Applications: GM-CSF as tested a therapeutic potential in a murine model of pulmonary aspergillosis. In summary, this pilot study indicates that GM-CSF administered intranasally may be a novel therapeutic approach for the prevention or treatment of pulmonary fungal infections and may augment the efficacies of antifungal agents.
GM-CSF was given intranasal.
4.Title: Dendritic Cell-Based Therapeutic Vaccination against Myeloma: Vaccine Formulation Determines Efficacy against Light Chain Myeloma
Publication: The Journal of Immunology February 1, 2009 vol. 182 no. 3 1667-1673
Link:
http://www.jimmunol.org/content/182/3/1667.full
5.Title:Pre-clinical Evaluation of a CEA DNA Prime/protein Boost Vaccination Strategy Against Colorectal Cancer.
Publication:Article first published online: 21 JUN 2007 DOI:10.1111/j.1365-3083.2007.01945.x
Scandinavian Journal of Immunology Volume 66, Issue 1, pages 43–51, July 2007
Link:http://onlinelibrary.wiley.com/doi/10.1111/j.1365-3083.2007.01945.x/full
6.Title:Intranasal Granulocyte-Macrophage Colony-Stimulating Factor Reduces the AspergillusBurden in an Immunosuppressed Murine Model of Pulmonary Aspergillosis.
Publication: First published November 2007, doi: 10.1128/?AAC.00760-07 Antimicrob. Agents Chemother. February 2008 vol. 52 no. 2 716-718
Link:http://aac.asm.org/content/52/2/716.full
UsageProSpecs products are furnished for LABORATORY RESEARCH USE ONLY. The product may not be used as drugs, agricultural or pesticidal products, food additives or household chemicals.
Prodigiosin/灵菌红素的PubChem识别号5351169
优质前列腺素E2Mouse PGE2,PG-E2 ELISA试剂盒有国外文献支持
进口操作说明重组二甲基甘氨酸氧化酶/DMGO
以色列进口小鼠白介素-6/IL 6 Mouse
人胃泌素(Gastrin)ELISA试剂盒Human Gastrin ELISA Kit
人胃动素(MTL)ELISA试剂盒Human MTL ELISA Kit
人胃蛋白酶(PG)ELISA试剂盒Human Pepsin ELISA Kit
人维生素D3(VD3)ELISA试剂盒Human VD3 ELISA kit
人维生素B1(VB1)ELISA试剂盒Human Vitamin B1 ELISA kit
人晚期氧化蛋白产物(AOPP)ELISA试剂盒Human AOPP ELISA Kit
人晚期糖基化终末产物受体(RAGE/AGER)ELISA试剂盒Human RAGE/AGER ELISA Kit
人晚期糖基化终末产物(AGEs)ELISA试剂盒Human AGEs ELISA Kit
人唾液酸(SA)ELISA试剂盒Human,SA ELISA Kit
人褪黑素(MT)ELISA试剂盒Human,MT ELISA Kit
人透明质酸(HA)ELISA试剂盒Human,HA ELISA Kit
人同型半胱氨酸(Hcy)ELISA试剂盒Human,Hcy ELISA试剂盒
人铁蛋白(FE)ELISA试剂盒Human,FE ELISA试剂盒
人天门冬氨酸氨基转移酶(AST)ELISA试剂盒Human AST ELISA试剂盒
人糖原磷酸化酶同工酶BB(GP-BB)ELISA试剂盒Human GP-BB ELISA试剂盒
