方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The Canadian Grain Commission, the regulatory department within the Canadian government which regulates grain trade in Canada, has a testing procedure for buckwheat in their grain standards. This testing procedure uses the Carter Day Dockage tester and has specific sieves and settings for the separation of dockage from Buckwheat. This test method would be used for the evaluation of a shipment of buckwheat for the determination of grade or quality. There are other small capacity cleaners for the general cleaning of a large bulk of buckwheat. These cleaners would separate out the good kernels of buckwheat from the chaff and debris.
INSPECTION OF BUCKWHEAT 荞麦检验
荞麦分级定等国际方法概述
美麦检测规程
