方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Underlying near-field optical effects on the nanoscale have stimulated the development of apertureless vibrational spectroscopy and imaging with ultrahigh spatial resolution. We demonstrate tip-enhanced Raman spectra of single-walled carbon nanotubes(SWCNTs), recorded with a scanning near-field optical spectrometer using both atomic force(AF)and shear force(SF)feedback lock-in regulation, and critically discuss the advantages and drawbacks of both operation modes. For accurate calculation of the enhancement factor obtained, we have analysed the tip shape and diameter by means of scanning electron and transmission electron microscopy(SEM and TEM).In our experiments we reproducibly attain diameter-corrected and area-corrected enhancement factors of up to ~10^4 and ~10^5, respectively, estimated as the linear ratio of near- and far-field intensities, and we are able to demonstrate near-field Raman imaging of SWCNTs with spatial resolution better than 50nm.
Nano-scale characterizationwith STM and TERS
voltage-dependent STM-TERS
TERS针尖增强拉曼
