方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Toehold-mediated strand displacement reaction (SDR) is first introduced to develop a simple quartz crystal microbalance (QCM) biosensor without an enzyme or label at normal temperature for highly selective and sensitive detection of single-nucleotide polymorphism (SNP) in the p53 tumor suppressor gene. A hairpin capture probe with an external toehold is designed and immobilized on the gold electrode surface of QCM. A successive SDR is initiated by the target sequence hybridization with the toehold domain and ends with the unfolding of the capture probe. Finally, the open-loop capture probe hybridizes with the streptavidincoupled reporter probe as an efficient mass amplifier to enhance the QCM signal. The proposed biosensor displays remarkable specificity to target the p53 gene fragment against single-base mutant sequences (e.g., the largest discrimination factor is 63 to C−C mismatch) and high sensitivity with the detection limit of 0.3 nM at 20 °C. As the crucial component of the fabricated biosensor for providing the high discrimination capability, the design rationale of the capture probe is further verified by fluorescence sensing and atomic force microscopy imaging. Additionally, a recovery of 84.1% is obtained when detecting the target sequence in spiked HeLa cells lysate, demonstrating the feasibility of employing this biosensor in detecting SNPs in biological samples.
QSense耗散型石英晶体微天平在制药领域中的应用
使用QCM-D 进行清洁研究
海南大学化工学院李嘉诚教授利用石英晶体微天平技术研究光响应性海藻酸基大分子表面活性剂与疏水叶片表面的相互作用
Attension Theta Flow 光学接触角测量仪
QSense High Pressure 高压石英晶体微天平
QSense全自动八通道石英晶体微天平
QSense卓越版四通道石英晶体微天平
QSense Explorer扩展版石英晶体微天平
KSV NIMA roll to roll 柔性LB膜制备系统
KSV NIMA LB膜分析仪
Attension Theta Flex 光学接触角仪
KSV NIMA Microbam 独立式小型布鲁斯特角显微镜
KSV NIMA 布鲁斯特显微镜
KSV NIMA常规 交替型LB膜分析仪
KSV NIMA 缎带型Langmuir膜分析仪
KSV NIMA Langmuir膜分析仪
QSense 石英晶体微天平定制表面芯片
高温高压表面/界面测量系统
