资料下载Waterproof platform scales WPT/H EX series is designed for operating in explosive areas and it is intended to precisely determine mass of weighed loads in laboratory and industrial conditions. The indicator and the weighing platform operate in the explosive area. They are powered by intrinsically safe power adapter model ZRi02 manufactured by RADWAG. The power adapter operates outside the EX zone, it features a diode barrier and it is plugged to mains 230 V. The length of an intrinsically safe power cord connecting the indicator and the power adapter is max 20 meters. The WPT/H EX series is designed to operate in EX zones 1 and 2 of mixtures of explosive vapours, gasses and fogs with the air, included in the explosive group IIB and temperature classes T1, T2, T3 and T4. The waterproof platform scales WPT/H EX series is intended to operate in areas with high humidity or with direct contact with water. They feature stainless steel indicator PUE C31/H series with backlit LCD display and 5 function buttons. The indicator is attached to the weighing platform with a stainless steel pillar. Optionally, the indicator is connected through a 3 m long cable and features a bracket for placing on a weighing table or mounting on wall. Scale components are fully made of stainless steel OH18N9.
德国Knick 902_电导率资料.pdf
简介:聪明。经人体工程学优化,适合现场和实验室使用。 集成的可移除式护袋可保护传感器。多功能挂钩确保其自由移动,设备可悬挂起来,或与可反转保护盖一起竖直放置。 德国Knick Portavo 902 标准型 pH、电导率分析仪采用Memosens技术的全球首款便携式pH计、电导率仪。 结实。结实可靠且耐化学腐蚀的外壳通过了从1米高处坠落到水泥地的标准坠落测试。高对比度LCD采用防刮擦的矿物玻璃屏幕,使用多年后仍然清晰无比。
德国Knick 902_pH资料.pd
简介:德国Knick Portavo 902 标准型 pH、电导率分析仪采用Memosens技术的全球首款便携式pH计、电导率仪。 聪明。经人体工程学优化,适合现场和实验室使用。 集成的可移除式护袋可保护传感器。多功能挂钩确保其自由移动,设备可悬挂起来,或与可反转保护盖一起竖直放置。 结实。结实可靠且耐化学腐蚀的外壳通过了从1米高处坠落到水泥地的标准坠落测试。高对比度LCD采用防刮擦的矿物玻璃屏幕,使用多年后仍然清晰无比。
德国Knick 904_pH.pdf
简介:Portavo 904 专业型 pH、电导率、氧分析仪采用Memosens技术的全球首款便携式pH值、电导率和氧含量测量设备。 结实可靠且耐化学腐蚀的外壳通过了从1米高处坠落到水泥地的标准坠落测试。高对比度LCD采用防刮擦的矿物玻璃屏幕,使用多年后仍然清晰无比。
德国Knick Stratos_Evo过程分析(pH、电导率、溶解氧).pdf
简介:格外丰富的功能和面向应用的设计,使Stratos品牌成功立足于整个化学行业、加工行业、发电厂,以及制药和生物技术行业的许多领域。 普遍适用的选项支持室内和室外应用、所有能想到的网络架构以及与几乎所有液体分析传感器的无限组合,这使得Stratos成为国内和国际生产系统的标准产品。
德国Knick Protos 3400过程分析(pH、电导率、溶解氧).pdf
简介: Protos 3400模块式过程分析系统: – 支持各种要求的灵活测量系统,多通道测量 – 极其丰富的资产管理功能 – 模块式硬件和软件概念允许随时改装 现场总线连接 利用Protos 3400过程分析系统,Unical 9000和Uniclean 900允许系统与PROFIBUS PA和Fieldbus Foundation直接集成。结合最新ProgaLog 3000参数设置和文档处理工具,该系统可以在PC上以离线方式轻松进行配置和文档处理。
