方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Scope 1. This test method covers laboratory procedures for determining the resistance of metallic materials to scratching abrasion by means of the wet sand/rubber wheel test. It is the intent of this procedure to provide data that will reproducibly rank materials in their resistance to scratching abrasion under a specified set of conditions. 2. Abrasion test results are reported as volume loss in cubic millimeters. Materials of higher abrasion resistance will have a lower volume loss. 3. The values stated in SI units are to be regarded as the standard. The values given in parentheses are for information only. This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
日本HEIDON 摩擦磨损试验机 纤维制品问题解决实例
日本HEIDON 摩擦磨损试验机 药品化妆品问题解决实例
日本HEIDON 摩擦磨损试验机 电力精密仪器问题解决实例
德国WAZAU UL94 水平垂直燃烧测试仪
德国WAZAU GPD 灼热丝试验机
进口德国EA(HCK) 高压测试仪/耐压测试仪
IOP-A 进口绝缘油击穿测试仪
日本新东HEIDON BL系列 通用搅拌器
MSE-S 表面涂层综合性能评价试验机
热管试验机
日本新东HEIDON Type:38 表面性能试验机
进口日本新东HEIDON Type 14FW表面性能测量仪
日本新东HEIDON 便携式静摩擦系数测试仪
进口德国WAZAU TPP织物防火性能测试仪
进口德国WAZAU INB 建筑材料不燃性试验机
德国WAZAU SPT 防护服织物防热性能测试仪
进口德国WAZAU MMS 防护服金属熔珠飞溅试验
进口德国WAZAU CHD 防护服热传导测试仪
