资料下载Abstract The commercialattractivenessof rolls with greaterresistanceto wearandfatiguedamageis substantial.providing reducedrolling mil down times. increasedroll life. reducedproductsurfacedefectsand improvedstockgaugetolerances.Relatively little is known about1&' wearmechanismsof thesematerialswhich limit the usefullife of cold rolling mill work rolls.Two steelsof composition0.8%C/3%Craid 0.8%C/5%Cr. which are representativeof industry standardmaterials.havebeentestedin a rolling-sliding configuration (slippage.8C1t-againsta high speedsteel (M2) counterface.A comparisonhasbeenmadebetweensamplesmanufacturedby conventional processiDl (castingandforging) andby sprayforming. Sprayforming provideda microstructuresimilar to thatof the heavilyforged materialbutwitJt afiner averagecarbidesize (134 nm in thesprayformedand317nm in theforged,bothfor the3%Crsteels)andthesprayformedmaterill did not containthe occasionalcoarsecarbides( - 2 ~m) found in theforgedmaterial.The increasein Cr contentfrom 3% to 5%changed thecarbidefrom (Fe.Cr)3C (3%Cr steel) to (Fe.Cr)7C3(5%Crsteel) in bothsprayformedandforgedmaterials.However.boththe~ sizeandcarbidetype hadlittle effectonwearratewhentestedin thequenchedandtemperedcondition.Temperingof thequenchedsteelwa.s; undertakenin thetemperaturerange200-500 °c. which yieldedhardnessin the range540-890 H. for the 3% Cr steeland470-880 H. fIX" the 5% Cr steel. The wear coefficient decreasedsignificantly for an increase in hardnessfrom to 470 H.(k-l.72X 10-5mm3 N-1 m-l) ~ 750 H. (k-l.35X10-6 mm3N-1 m-l)but only fell slightly for hardnessvaluesabove750 H.. The friction coefficient was0.49-0.6.1': irrespectiveof loador materialtemper.Characterisationof worn surfacesindicatedthatsurfacestrainwaslimited to adepthof - 5-15 ~
用于测定表面耐磨性的方法和装置
简介:TAPERADER®是一台便携式磨损表面测量仪,用于实时现场测试,数据真实可靠。该产品拥有国际、国内多项专利。TAPERADER®具有应用范围广的特点,可对钢铁、有色金属、陶瓷、塑料等制品的表面进行测试。应用领域涉及汽车,石油,薄膜润滑等方面。
国际标准IEC 68-2-70以及相关的企业标准
简介:ABREX®多功能手指磨耗仪是世界上唯一一台能够模拟人类手指及皮肤摩擦的试验机。该设备是国际标准及诸多国际知名企业的指定标准设备。 IEC 68-2-70.pdf GS97034-1.pdf GS97034-2.pdf GS97034-4.pdf GS97034-5.pdf GS97034-6.pdf
