方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Boronising is a time/temperature dependent diffusion tre.tment similar to carburising and nitriding which can be carried out in liquid;solid or gaseous media. Using a pack medium. the authors have established time/temperature parameters to produce different coating thicknesses on steels with. range of carbon contents and h.ve determined friction .nd wear char.cteristics of treated Samples under dry conditions. Boronising inhibits adhesive wear during running-in and suppresses the transition from mild to severear. Abrasive we.r resistnce is also improved. compared with on-boronised and carburised steel. and depends upon both substrate materia.and coating thickness.
案例分析-凸轮轴
案例分析-手指磨耗测试仪对汽车内饰件磨耗的测定
案例分析-气门
