方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Wear of piston rings and cylinder liners has been examined tLSing a wide rang of techniques and a very good cOTT~lation has been obtained through the use of these, with the w~ar behavior in servic engines, test-bed tngines, and laboratory tests. This should form the basis for further eelopment of mattriaLr, particularly surface coatings, to inCT~as~ both the ~fficienC)' and w~ar lif~ of the componnIts. A clear pictur~ of the wear mechanisms including abrasion,scuffing, and corrosion has emerg~d, but much remains to be done,particularly in inttTT~lating wear and lubrication to produce smooth, etched, long-lif~ surfaces. A wear debris atlas is available which, however, is somewhat limited in its tLSe and information should be collected to establish a "wear atlas," particularly for will establish~d contacting bodies and for specific engin ering applications. Much of this information is already available for piston rings and rylindtr liners, some of which is presented in this investigation.
案例分析-凸轮轴
案例分析-手指磨耗测试仪对汽车内饰件磨耗的测定
案例分析-气门
