方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A linear model of lubricant-related engine friction was developed.Based on lubrication {undamentcils, the technique is comprised of three simple bench tests that respectiuel_v operate under thick fluid-film hy~ynamic lubrication, elastoh)drodynamic lubrication,and boundary lubrication. With adequate configuration and appropriate test conditions, these bench tests are seen to simulate major friction losses in a typical internal combustion engine.
案例分析-凸轮轴
案例分析-手指磨耗测试仪对汽车内饰件磨耗的测定
案例分析-气门
