paper 635 微动检测涂层强度
2012/03/13   下载量: 2
方案下载
应用领域
检测样本
检测项目
参考标准
Abstract Considered as a plague for numerous industrial assemblies, fretting, associated to slight oscillatory displacement, is encountered in all quasi-static contacts subjected to vibration. Depending on sliding conditions, cracking or wear damage can be observed. During the past three decades there has been a huge development in surface treatments. Thousands of new surface treatments and coatings are now available. The critical challenge is to evaluate such treatments against fretting loadings. To achieve this objective, a fast fretting methodology has been developed. It consists in quantifying the palliative friction, cracking and wear responses through a very small number of fretting tests. By defining quantitative variables, a normalized polar fretting damage chart approach is introduced. Applied to shot peening, chromium coatings and WC-Co coatings, it demonstrates the potential benefit of a thermal sprayed WC-Co coating. © 2005 Elsevier B.V. All rights reserved.
方案下载
上一篇 案例分析-凸轮轴
下一篇 paper 075 橡胶材料摩擦试验机
文献贡献者
相关方案
当前位置: 奥码拓 方案 paper 635 微动检测涂层强度
