方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Antibody-antigen binding may be monitored on the SPRimager II either by (i) immobilizing antigen (or peptide eitopes) on gold chips, then exposing them to antibody solution. In this example, biotin-labelled antibodies are immobilized on streptavidin-coated SpotReady chips. Specific binding of IFN antigen to anti-IFN antibody is demostrated, confirming that immobilized antibody is active. A biotinylated oligonucleotide ligan binds only to control streptavidin spots with no antibody attached, confirming the functional activity of the streptaviin surface and the specifity of the antigen binding.
MULTI-CLEANER M08/M12正压净化装置在二恶英类化合物分析中的应用
白酒中塑化剂的固相萃取
食品安全检测中固相萃取技术的应用及技巧
