方案下载应用领域 | 石油/化工 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 无 |
The Raman spectra of elemental carbon materials are known to be sensitive to polymorphy. For hard carbon films, the spectra of amorphous and diamond-like carbons can be band-fit to separate the contributions of the "graphitic carbon" (G band) from the "disordered carbon" (D band). The spectral behaviour of carbon films has been empirically correlated with thin film physical properties such as hardness, durability, optical transparency, electrical conductivity, thermal conductivity and corrosion resistance, and can be of use for prediction of these properties without extensive alternative testing.
显微拉曼光谱在电化学中的应用原位锂离子电池研究
拉曼光谱在锂离子电池研究中的应用
光谱分析助力锂电池产业突破:固态电解质锂电池的原位研究
Nanoscope system K1-Fluo 激光荧光共聚焦显微镜
Nanoscope system NS3600 三维激光共聚焦显微镜
Nanoscope system NS3500三维激光共聚焦显微镜
SUNANO STHP-F系列超纯水机
SUNANO STUP-C系列超纯水机
ST-II型气垫精密光学隔振平台
CRAIC FLEX 紫外-近红外显微分光光度计
CRAIC rIQ折射率定量分析仪
CRAIC 508PV 显微分光光度计
CRAIC CoalPro Ⅲ煤岩镜质体反射率测量仪
CRAIC ELIXIR多功能显微分光光度计
CRAIC UVM-1全光谱显微镜
Lyncee Tec 高速光学三维质量检测仪
Lyncee Tec 4D反射测量仪
Lyncee Tec MEMS全息测振分析仪
