Spectra-UT 超光谱校准光源
出色的可编程高分辨率光谱输出
基于我们在固态可调光源方面的经验,Spectra-UT超光谱校准光源使用连续谱光源和多色仪技术,可对生成的光谱波形提供精确的控制。 Spectra-UT超光谱校准光源可以精确地再现复杂的光谱特征,从而实现对标准光源以及自然或合成光源和发射源的高分辨率光谱模拟。Spectra-UT 超光谱校准光源是一种适用于平场校正的均匀光源,并可以兼容光导管和准直器输出,用于样品的特殊光谱照明。 Spectra-UT能够通过一种复杂的光谱匹配算法,在可见光区域产生近乎完美的任意目标光谱波形。它可以模拟约10 nm半高全宽度的光谱,宽谱可见光光谱和复杂的光谱形状。 Building on our experience with solid-state tunable light sources, Spectra-UT Ultra Tunable Spectral Calibration Sources use a continuous-spectrum light source and polychromator technology to offer incomparable control over generated spectral waveforms. Spectra-UT Sources can reproduce complex spectral features with a precision that enables high-resolution simulation of standard illuminants as well as natural or synthetic sources and emissions. Spectra-UT is a uniform source for flat-fielding applications and can be adapted to optical light guides and collimators for remote sample spectral illumination. Spectra-UT is capable of producing a near-perfect match to almost any target spectral waveform in the visible-light region by using a sophisticated spectral matching algorithm. It can render narrow-band targets on the order of 10 nm full-width half-max, broad VIS spectra and complex shapes. • 出色的可编程高分辨率光谱输出 Benefits • 色度计和分光光度计校准 Applications |
可见光范围最大输出亮度:Max Output Power in Visible Range: | 4000 cd/m2 |
亮度调节范围:Light Control Levels: | 25 cd/m2 - 1000 cd/m2 |
亮度均匀性:Luminance Uniformity: | 99% |
光谱范围:Spectral Range: | 390 nm – 780 nm |
FWHM: | 12 nm ± 2 nm |
峰值波长间距:Peak Wavelength Separation: | 0.4 nm |
光谱精度:Spectral Monitor Accuracy: | < 0.5 nm |
最快光谱扫描率:Spectral Monitor Scan Rate: | < 1.0 光谱/秒 |
蓝菲光学邀您参加第25届CIOE中国国际光电博览会
蓝菲光学亚太区代理商研讨会圆满落幕,共谋合作发展大计
Labsphere成功并购ILT,携手共创光技术领域新纪元
蓝菲光学邀您参加2024年慕尼黑上海光博会
手持光谱反射率测试仪+Labsphere蓝菲光学+LFHH-1000
激光功率计-激光功率测试仪-激光功率积分球
黑色漫反射目标板
积分球单色光源
太阳光模拟积分球均匀光源
CCS准直太阳光模拟器
光致发光荧光量子效率测试系统
温控积分球光谱仪测量系统
激光积分球蓝菲光学Labsphere
漫反射白板+漫反射标准白板+Labsphere蓝菲光学漫反射板
超光谱校准积分球光源-Labsphere蓝菲光学积分球光源
可调光谱积分球校准光源-Labsphere蓝菲光学积分球光源
工业相机校准光源-LED积分球均匀光源(SPECTRA-CT )
功率可调积分球校准光源-Labsphere蓝菲光学积分球光源
激光雷达测试漫反射板+LiDAR漫反射板
