资料下载驱动器、泵头、胶管的配套使用 Flow ranges are approximate—calculated under the following conditions: 0 psig at inlet, 0.5 psig at outlet; water temperature at 72°F (22°C). Actual performance varies depending on tubing formulation—values shown below are for firm tubing.
DC704
简介:高真空技术中使用的扩散泵油,要求耐热氧化性,冷却温度下蒸汽压低,且其蒸汽压随温度变化大,沸腾温度不能过高。早期曾使用水银,目前主要使用矿油类、脂类、聚苯醚及硅油等。其中以硅油的性能最好,它具有热氧化性高、粘温系数小、沸点范围窄、蒸汽压曲线陡(温度变化一点,蒸汽压变化很大),常温蒸汽压低,凝固点低加之化学惰性,无毒、无味、无腐蚀。
离心机5810 5810R
简介:历史悠久的Eppendorf台式离心机在过去的每一年中被广泛使用。因而,Eppendorf非常自然将开发的离心机新技术应用于活细胞处理。因而5804/5804R和5810/5810R虽是一款具备同样底盘的设备,但却拥有改良的控制面板和融汇先进工艺的内在 生命力!
旋转震荡器的型号选型
简介:·Holds a wide variety of tubes,flasks,microplates,bags and odd-shaped vessels at virtually any angle ·Available with two different platforms(standard and magnetic) which can be interchanged for added versatility
菌落计数器的描述与型号
简介:Combines the permanent marking of a Sharpie®pen with a precise electrical counter!
振荡培养箱的型号规格
简介:•Precise temperature control and uniformity •Magnetized stainless steel platform can rock or rotate almost any container
