资料下载The all-new design of the Easy-Load® 3 features an automatic retention mechanism that makes loading and unloading tubing easier than ever. The spring-loaded occlusion lever opens the occlusion bed and simultaneously retracts the tubing retainers so that tubing slips right in. Close the lever and start the pump—the retainers automatically grip and hold the tubing securely in place. The occlusion bed applies optimal occlusion force and the wide occlusion angle prevents fluid backflow up to the rated pressure of the tubing.
DC704
简介:高真空技术中使用的扩散泵油,要求耐热氧化性,冷却温度下蒸汽压低,且其蒸汽压随温度变化大,沸腾温度不能过高。早期曾使用水银,目前主要使用矿油类、脂类、聚苯醚及硅油等。其中以硅油的性能最好,它具有热氧化性高、粘温系数小、沸点范围窄、蒸汽压曲线陡(温度变化一点,蒸汽压变化很大),常温蒸汽压低,凝固点低加之化学惰性,无毒、无味、无腐蚀。
离心机5810 5810R
简介:历史悠久的Eppendorf台式离心机在过去的每一年中被广泛使用。因而,Eppendorf非常自然将开发的离心机新技术应用于活细胞处理。因而5804/5804R和5810/5810R虽是一款具备同样底盘的设备,但却拥有改良的控制面板和融汇先进工艺的内在 生命力!
旋转震荡器的型号选型
简介:·Holds a wide variety of tubes,flasks,microplates,bags and odd-shaped vessels at virtually any angle ·Available with two different platforms(standard and magnetic) which can be interchanged for added versatility
菌落计数器的描述与型号
简介:Combines the permanent marking of a Sharpie®pen with a precise electrical counter!
振荡培养箱的型号规格
简介:•Precise temperature control and uniformity •Magnetized stainless steel platform can rock or rotate almost any container
