资料下载Ultra High Performance Liquid Chromatography (UHPLC) sample prep filtration significantly increases column life and improves chromatography Optimized Performance – Ideal for UHPLC sample prep and buffer filtration when using column packings < 2 µm. Versatile Options – Available in a variety of polymers to provide chemical compatibility with all solutions. Increased Flow – GxF multilayer prefilter provides two to four times more throughput than standard glass fiber prefilter devices, allowing quick and easy filtration of your most difficult to filter solutions. Minimal UV Absorption – Nylon, GHP, PTFE and PVDF membranes are HPLC certified to be low in UV absorbing extractables for less interference with chromatographic results. Low Hold-up – 13 mm minispike outlet for lower hold-up volume and easy filtration into autosampler vials without airlock. Automation Certified – Acrodisc® PSF is Sotax
颇尔新一代智能纯水仪Cascada1
简介:? 稳定真实的金标准水质,水质数据所见即所得 ? 独特的水箱水质监控元件,监控水箱取水水质 ? 全球第一款实验室7英寸超大彩色触摸屏进口品牌水机,所需信息,一览无遗 ? 智能触控,一页尽览,友好人机互动 ? 取水方式灵活便捷,界面直观操作,实验室空间得以优化 ? 适合中国源水特点,根据中国源水情况设计的预处理组件,所安装的产品全在眼前 ? 大容量耗材,更长的使用时间。 ? 耗材更换方便,主机提供动画演示,耗材内嵌芯片,可确保耗材正确使用 ? 脚踏及远程,灵活取水手臂可选,实现用水灵活性 ? 自动校准功能,保证定量取水精度 ? 独特的双级反渗透技术,得到稳定产水水质 ? 数据永久记录,打印设备导出 ? 流速可调,可选择
颇尔新一代智能纯水仪Cascada 3
颇尔新一代智能纯水仪Cascada 3.1
颇尔新一代智能纯水仪Cascada 2.1
DMSO专用Acrodisc针头滤器
简介:聚丙烯外壳和尼龙膜与含有DMSO的溶液兼容,与酯和酒精有良好的化学兼容性。用于细胞低温储藏介质的灭菌。
