PortLog便携式自动气象站英文样本
2012-10-25 16:31  下载量:6
资料下载
The PortLog is a compact rugged industrial grade data logging weather station. The unit is fully assembled and can be quickly deployed. The large 3-Watt solar panel and 4AH sealed lead acid battery ensure reliable operation in the harshest conditions. The non-volatile memory can provide data storage for up to 9 months at a one-hour logging rate. The user selectable rate can be adjusted down to one minute. Memory upgrades are available for extended logging applications. The PortLog memory can be configured to wrap or stop logging when full. In wrapping mode, the oldest record is replaced with newest when the memory if full. Wind speed records include peak and average speeds for the interval. The average direction is recorded. The remaining parameters are instantaneous readings. Data is output in comma-delimited text (CSV). Microsoft Excel can be used to view, graph and manipulate the data.
资料下载
文献贡献者
相关资料 更多
当前位置: 拜能仪器 资料 PortLog便携式自动气象站英文样本
