资料下载The Unitec SENS-IT sensors are innovative, compact and low cost devices for environmental air quality monitoring. Based onUnitec proprietary technology, each SENS-IT sensor is specific for a single pollutant gas (CO, NO2 , O3 , C6H6 …) with extremely high sensitivity and selectivity (also at low ppb levels). Each sensor is engineered in an anodized aluminum case with new embedded electronic board for totally digital control of sensor performances. The RS485 interface permits to easily integrate the sensors in existing devices or monitoring networks, control digitally all the functioning parameters and calibrate them also from remote. The SENS-IT sensors exploits the advantages of the Thick Film Metal Oxide Semiconductor Technology (TF-MOS) for CO, NO2, O3, C6H6, and CH4 monitoring. The active surface of the sensor is based on a specific nano-structured semiconductor metal oxide. The first reaction which happens on the surface of the sensor is the adsorption of atmospheric oxygen with consequent charge transfer from semiconductor to oxygen molecules. The second reaction is related to specific gas to monitor, which while reacts with adsorbed oxygen (through Red-Ox reactions) allows the electrons to be released in the conduction band of the semiconductor. Taking the current signals from the sensors during these reactions, the direct concentration of the specific gas can be measured. Selectivity and sensitivity are reached using special doped semiconductor metal oxides, in addition, the stability and no consumption of active surface guarantees long term high repeatability and low maintenance needs. Monitoring of SO2, H2S, NH3, VOC, CO2 is also available using SENS-IT sensors based on traditional Electrochemical Technology (EC) or Infrared Technology (IR).
Gill TFT风显示器-中文彩页
简介:多功能 TFT 风显示器可以在气象(N-E-S-W) 或海洋(左舷/右舷)模式下显示风速和风向。 风信息显示采用8.5英寸LED背光,工业级液晶屏,以170°真视角显示数据。 多功能 TFT 风显示器在 NMEA 模式下直接从风传感器接收数据,无需额外的接口。 它为风传感器提供电源,并且可以“菊花链”到第二个风显示器以传输风传感器信息。
RPR WS15-A气象显示器-中文彩页
简介:WS-15A气象数据显示器可以与Gill WindSonic超声波风速仪或MetPak专业气象站或MaxiMet紧凑型气象站配合使用,为气象数据在线监测提供了一种经济实惠、高效精确的解决方案。WS-15A显示器带有LCD显示屏,字母和数字能够显示风速值、风速单位、风向角度值,以及箭头来显示大致风向。可设置风速警报值,还可以显示传感器和系统状态。
Kalyx-RG翻斗式雨量计-中文彩页
简介:Kalyx-RG是一款经济高效的空气动力学“翻斗式”雨量计,可以最大限度地减少风对降雨量的影响。与常规形状的翻斗式雨量计相比,该形状的雨量计可以捕获更多的降水,测量的数据更加准确。Kalyx-RG 是一款紧凑的雨量解决方案,对于任何关心数据质量的人来说,它都是理想的雨量测量仪器,它使用校准至 0.2 毫米分辨率的低密度塑料翻斗,并由紫外线稳定的外部材料制成。
AirMar P319/B117测深声呐-中文彩页
简介:P319和B117是一款穿舱式安装方式的测深声呐,功率600W,采用50/200 kHz双频单陶瓷元件,外形小巧。 近乎齐平的地剖面设计将阻力降至最低,仅有5毫米(3/16英寸)延伸到船体外部。P319是塑料材质,与之功能对应的是B117青铜材质,适用于不同材质的船体。
AirMar B60/SS60测深声呐-中文彩页
简介:B60和SS60一款是双频段50/200 kHz的采用内置的陶瓷元件倾斜测深声呐。近乎齐平的低剖面设计,可补偿船体倾斜角度,可将阻力降至最低,仅有5毫米(3/16英寸)延伸到船体外部。内置的倾斜补偿,可减少倾斜带来的性能损害。这种特殊的设计提供了类似于使用整流罩的专业的优点,又几乎与船体齐平的。 在高达24°的陡峭倾斜船体上,声波波束向下瞄准,可以获得很强的声波反馈和精确的深度读数。B60是青铜材质的,与之对应的是SS60不锈钢材质的,适用于不同材质的船体。
Davis 6464翻斗式雨量计
Geonica 6135雷达水位计
Geonica 6115雷达水位计
拜能仪器BN-RL雷达水位计
Hukseflux IR20WS长波辐射表
Hukseflux IR20长波辐射表
Hukseflux IR02-TR长波辐射表
Hukseflux IR02长波辐射表
Hukseflux SR25二级总辐射表
Hukseflux SR22二级总辐射表
Hukseflux SR20-D2二级总辐射表
Hukseflux SR20二级总辐射表
Hukseflux SR05-D1A3-PV总辐射表
Hukseflux SR05-A1二级总辐射表
Hukseflux SR05-D2A2二级总辐射表
