资料下载A group of novel taxoids, with modifications at C-7, C-10, C-30 and C-14 positions of paclitaxel, was synthesized in order to improve their biological profile by decreasing their affinity with P-glycoprotein (Pgp) and increasing cellular permeability. Most of the new taxoids demonstrated the similar potent cytotoxic activities in MCF-7 human tumor cell line as paclitaxel in vitro. In the permeability assay with monolayers of Caco-2 cells, most of the compounds demonstrated an increased trans-cellular transport in Ato- B direction in comparison with paclitaxel. Among them the compounds T-13, T-15 and T-26 showed the highest permeability, and with efflux ratios better than that of ortataxel. The interaction of the compounds T-13 and T-26 with P-gp was evaluated using Madin-Darby canine kidney (MDCK)-multidrug resistance-1(MDR1) and MDCK-wild-type (WT). The results indicated that T-13 and T-26 were poor substrates for P-gp and possessed inhibiting effects of P-gp mediated efflux. It was thus clear that simultaneous modifications at the C-7, C-10 and C-30 positions of paclitaxel significantly impaired its interactions with P-gp and interfered with P-gp mediated efflux.
Thiadiazolidine 1-oxide systems for phosphine-free palladium-mediated catalysis by Biotage Initiator耐士科技
简介:We herein report several highly active catalyst systems with thiadiazolidine 1-oxides as ligands for palladium in the MizorokieHeck reaction. Excellent yields of stilbenes derived from aryl iodides and bromides have been achieved using as little as 0.00002 mol % catalyst. The ligand/palladiumsystem can be stored as a stock solution open to air at room temperature with no observable loss of activity for a period of several months.
Biotage Flash Isolera 快速制备液相色谱注意事项
简介:耐士科技作为Biotage中国区总代理,以优质的服务为您提供Biotage全系产品以及相关的技术服务。1、开机前确认自动收集机械手臂下无障碍物,试管高度低于机械手臂收集针 2、运行前确认所用流动相充足,废液瓶剩余空间充足
Biotage Isolera中低压制备快速使用手册
简介:操作步骤: 1.开机,按屏幕左下方黑色电源键 2.进入开机界面后,点击Chemistry进入操作界面 3.在”Method”页面中设定好相关参数
微波合成仪Initiatior快速使用手册
简介:耐士科技作为Biotage中国区总代理,以优质的服务为您提供Biotage全系产品以及相关的技术服务。 操作步骤: 1.开机,按屏幕左下方黑色电源键 2.进入开机界面后,点击 Organic Synthesis 进入编辑界面
氨基柱的使用与保养
简介:GRACE氨基柱可同时用于正相条件和反相条件,但是在一般情况下,正相溶剂与反相溶剂是不互溶的,在更换正反相时请先用异丙醇过渡,因为异丙醇粘度较大,因此流速建议调至0.5ml/min。 了解更多或订购产品,请致电耐士科技全国服务热线:400-188-0725
KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
