资料下载The preparation of an indole appended vinamidinium salt, an indole appended vinylogous amide and an indole appended chloroenal are described. The subsequent regiospecific conversion of these indole containing building blocks to functionalized pyrazoles and pyrroles is detailed.
Thiadiazolidine 1-oxide systems for phosphine-free palladium-mediated catalysis by Biotage Initiator耐士科技
简介:We herein report several highly active catalyst systems with thiadiazolidine 1-oxides as ligands for palladium in the MizorokieHeck reaction. Excellent yields of stilbenes derived from aryl iodides and bromides have been achieved using as little as 0.00002 mol % catalyst. The ligand/palladiumsystem can be stored as a stock solution open to air at room temperature with no observable loss of activity for a period of several months.
Biotage Flash Isolera 快速制备液相色谱注意事项
简介:耐士科技作为Biotage中国区总代理,以优质的服务为您提供Biotage全系产品以及相关的技术服务。1、开机前确认自动收集机械手臂下无障碍物,试管高度低于机械手臂收集针 2、运行前确认所用流动相充足,废液瓶剩余空间充足
Biotage Isolera中低压制备快速使用手册
简介:操作步骤: 1.开机,按屏幕左下方黑色电源键 2.进入开机界面后,点击Chemistry进入操作界面 3.在”Method”页面中设定好相关参数
微波合成仪Initiatior快速使用手册
简介:耐士科技作为Biotage中国区总代理,以优质的服务为您提供Biotage全系产品以及相关的技术服务。 操作步骤: 1.开机,按屏幕左下方黑色电源键 2.进入开机界面后,点击 Organic Synthesis 进入编辑界面
氨基柱的使用与保养
简介:GRACE氨基柱可同时用于正相条件和反相条件,但是在一般情况下,正相溶剂与反相溶剂是不互溶的,在更换正反相时请先用异丙醇过渡,因为异丙醇粘度较大,因此流速建议调至0.5ml/min。 了解更多或订购产品,请致电耐士科技全国服务热线:400-188-0725
KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
