Determination of Damaged Starch—
2012/05/31   下载量: 5
方案下载
应用领域
检测样本
检测项目
参考标准
Damaged starch is a very important flour quality parameter because it affects water absorption. To determine the extent of starch damage, this method measures the kinetics of iodine absorption in a liquid suspension, using an amperometricprobe. Results are given in an iodine absorption index percentage (AI%). An indication of the speed of iodine absorption in seconds is also reported as “Vabs”.The method is specific to white flour obtained from Triticum aestivum coming from either laboratory or industrial milling, but it can also be used on wholemeal flour.
方案下载
上一篇 AMS FRANCE:游泳池水中尿素的连续流动分析测定法
下一篇 An Amperometric method using the SDmatic
文献贡献者
KPM分析集团
银牌会员第13年
查看全部资料
相关方案
当前位置: KPM 方案 Determination of Damaged Starch—
