方案下载应用领域 | 其他 |
检测样本 | |
检测项目 | |
参考标准 | -- |
《Rheological, textural and sensory properties of gluten-free bread formulations based on rice and buckwheat flour》 Mixolab, as the rheological instrument, was utilized to create gluten-free products. According to obtained Mixolab profiles, mixtures of rice flour and husked buckwheat and rice flour and unhusked buckwheat flour expressed rheological properties similar to wheat flour. In both types of mixtures the ratio of rice flour to buckwheat flour was 90:10, 80:20 and 70:30. According to the Mixolab profiles of the investi¬gated systems, gluten-free products containing unhusked buckwheat flour had higher water absorption values, lower stability and weaker protein network structure, as well as lower peak viscosity than those consisted of husked buckwheat flour. Increasing the amount of husked buckwheat flour from 10% to 20% resulted in both G0 and yield stress value increase, but further increase of the husked buckwheat flour on 30% resulted in both G0 and yield stress value decrease. However, increasing the amount of unhusked buckwheat flour from 10% to 20% resulted in significant decrease of G0 and yield stress value having no significant impact with the addition of 30% of unhusked buckwheat flour. Hardness, expressed as a work of compression of the final product, increased with the amount of both types of buckwheat flour. Samples containing UBF expressed not significantly higher values of hardness than those prepared with HBF. According to obtained results of sensory evaluation of the final products it can be concluded that all six combinations of tested gluten-free breads were sensory acceptable. 如需阅读全文,请来函索取! 联系方式:info@chopinchina.com
AMS FRANCE:游泳池水中尿素的连续流动分析测定法
AMS FRANCE:Smartchem140全自动化学分析仪测定地表水中的硝酸盐
AMS FRANCE:Smartchem140全自动化学分析仪测定地表水中的亚硝酸盐
Futura II连续流动分析仪
Futura III连续流动分析仪
SmartChem140全自动间断化学分析仪
SmartChem 200土壤水质酒类全自动间断化学分析仪
SmartChem450全自动高通量间断化学分析仪
SmartChem600全自动高通量间断化学分析仪
iCinac乳品酸化分析仪
AlveoPC吹泡仪/育种高校研究院,三维分析面筋特性
Alveolab全自动吹泡仪/三维判定面筋特性麦谷蛋白醇溶蛋白评估,育种研发配粉高校科研单位
CD1实验磨粉机/小麦粉出粉率高粉路短易清洁
EM10标准专用烘箱/谷物粉水分干燥箱
Grinder谷物锤式旋风磨/大麦黑麦小麦等
LabMill全自动实验磨粉机/适用所有品种小麦的研磨测试
Mixolab 2混合试验仪/适用于所有谷物粉全麦粉的流变特性研究,相当于降落数值仪+粘度仪+粉质仪
Rheo F4 流变发酵仪/预制产品冷冻面团无麸质分析全麦粉醒发特性研究
