方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract In the present work, copper powder (purity—99.7%, grain size—63 Am maximum) was mechanically alloyed with lithium (purity>99%) in a SPEX ball mill. The alloying process was carried out for 15 h under an argon atmosphere using WC containers and stainless steel balls. The alloyed powders were then hot-consolidated by uniaxial hot pressing at different temperatures (300, 400, 500, and 550 jC) for 3 h at a pressure of 90 MPa, again under an argon atmosphere. The compacted samples were then characterized metallurgically, mechanically, and electrically; some of the properties (porosity, hardness, tensile strength, and electrical resistivity) are reported and analyzed in the present paper. The best results were obtained using a consolidation temperature of 400 jC—a condition which led to a microstructure showing low porosity, a hardness significantly higher than the other samples, and a tensile strength very similar to that for OFHC copper compacted in the same manner. The electrical resistivity was found to be small compared with that of other copper alloys used nowadays in large industrial applications. D 2003 Elsevier Inc. All rights reserved
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
