方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Surface and sub-surface oxidation of dispersed copper phase by N 2 O adsorptive decomposition at controlled temperature followed by H2 temperature-programmed-reduction of the Cu 2O surface layers formed (s-TPR) was performed on siliceous supported catalysts (ca. 6 wt.% Cu). The combined analysis permitted to measure the copper dispersion and to identify different surface copper species. 如需完整资料请来电咨询。
温控对密度计校准的重要性
当液氮液面稳定在50微米内对压力的影响
举例氯化钠在不同温度下的密度
