资料下载GB/T 13885-2003 动物饲料中钙铜铁镁锰钾钠和锌含量的测定原子吸收光谱法规定了用原子吸收光谱方法测定动物饲料中钙(Ca),铜(Cu)、铁(Fe),镁(Mg)、锰(Mn)、钾(K)、钠(Na)、锌(Zn)含量的方法。
哈克压力控制流变仪在橡胶方面的应用(English)
简介:1. Introduction and objectives A great variety of rubber parts is produced for the automotive industry. To minimize problems during the ssembly of the cars and to ensure best performance, the parts have to be manufactured with the smallest possible variation in size and shape. The size can be controlled by the extrusion and injection parameters – the shrinking of the material can often be well estimated.
红外光谱法定量分析轧制油中的醇,酯添加剂含量-210-280--MO0104
简介:轧制油是铝板、带、箔生产中重要的辅助材料,它直接影响到工艺的运行及最终产品的质量。轧制油的添加剂主要由醇、酯等组成,红外光谱分析中二者的特征吸收峰互不干扰,也不受背景(基础油)影响。根据朗伯-比尔定律可以得到各组分浓度与吸光度的工作曲线,从而准确地求出添加剂中各组分的浓度。本文实验中选用Specac公司提供的500um Pearl液体透射附件,不仅简化了实验操作,而且准确测试出待测样品的浓度。
RheologicalAnalysisofPowderCoatings.
简介:Powder coatings are a cost effective and an environmentally friendly alternative to liquid coatings. Traditional coating systems form networks via a thermally activated process.This usually involves placing a powder coated surface into an oven at temperatures between 160°C and 200°C. The powder melts at around 80°C to 120°C and becomes an even film. At temperatures between 110°C and 140°C the cross linking reaction starts. The curing time typically lasts between 15 and 30 minutes, depending on the temperature and reactivity of the system.
连日阴雨你有没有想过-红外光谱仪过得好吗?
简介:今年的梅雨季节感觉格外的长,环境湿度居高不下,经过长时间高湿环境的考验,你的红外光谱仪还好吗?今天力晶小天就为大家适时奉上这则红外光谱仪雨季防潮小贴士,希望大家关怀一下自己的红外哦。
赛默飞世尔Process11转矩流变仪产品样本
简介:Thermo Scientific Process 11双螺杆挤出机包含多种设置可能性:多个独立的进料和排气口,适用于快速更换圆棒线材直径的模具设计,以及旨在获取精确温度变化分布的八段机筒(每段长度:5L/D)。
标签胶专用流变仪
力学法表面张力仪(K100C)
动态泡沫分析仪(DFA100FSM)
接触角和表面张力分析仪(DSA25E)
接触角和表面张力分析仪(DSA100E)
接触角和表面张力分析仪(MSA Flexible Liquid)
微型双螺杆挤出机(HAAKE Process 11)
便携式粘度计(Viscotester™ 3)
便携式元素分析仪 MH-5000
便携式元素分析仪 (MH-5000)
便携式元素分析仪 MH-6000A
便携式元素分析仪 (MH-6000A)
赛默飞 旋转流变仪Viscotester iQ
旋转流变仪 HAAKE MARS iQ
旋转流变仪 HAAKE MARS iQ AIR
