资料下载The calender is sheet fed and has one heated steel roll and one polymer roll for super or soft calendering. The width of the polymer roll is 300 mm and the diameter is 250 mm, the heated steel roll diameter is 200 mm. The polymer roll can easily be exchanged for several different types of rolls as paper filled or steel.
旋转式鼓式干燥器操作手册
简介:Table of Contents目录表 Table of Contents目录表 Safety Notes and Warnings安全注意事项和警告 Description and Specifications产品说明和规格 Specifications规格 Installation Instructions安装说明 Operation操作 Maintenance维修 Repair and Replacement Parts 维修和更换零件 Warranty质量保证
PPS
简介:Profile/Plus是由美国Technidyne公司设计生产的成品纸自动测试系统,测试项目包括:白度、色差、不透明度、PPS印刷粗糙度、透气度/粗糙度、光泽度、厚度、纸张纸板基重、纤维配向和抗张强度、撕裂度 等等。此测试系统由PC软件控制。并采集大量数据产生即时的报告,用于统计、分析、传递或打印。取横幅纸样测试时,操作者根据菜单提示,其操作界面极易使用。
DT压光机操作手册
简介:Check that the hydraulic motor rotates in the right direction when starting the hydraulic unit for the first time after connecting to a new (previously not used) power supply. The calender is designed for 3~400 VAC + Grounding (L1, L2, L3 and PE). If a special power supply is requested, check the connection with the manufacturer(see electrical drawings). Replace the transportation bolt on the motor gear box with the plastic air plug.
成纸自动检测站
简介:自动成纸测试系统对造纸厂而言是一项巨大的投资。虽然它们 能够带来更高的速度、精度和效率以及便利性,但成本却相对较高。Technidyne 的创新团队发明了一种“积木式排列”自动成纸测试系统,即工厂可以从一台测试仪着手,慢 慢地增加测试仪器项目,可根据其生产和预算要求增添其他仪器项目。 Technidyne 的“积木式排列”自动 成纸测试系统可为造纸行业带来经济、创新、适应性强的自动化测试。
