资料下载ASTM-D 2863测量支持塑料类似蜡烛燃烧的最低氧气浓度(示氧值)的试验方法 This standard is issued under the fixed designation D 2863; the number immediately following the designation indicates the year of original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A superscript epsilon (e) indicates an editorial change since the last revision or reapproval. 1. Scope * 1.1 This test method covers a fire-test-response procedure. This test method describes a procedure for measuring the minimum concentration of oxygen that will just support flaming combustion in a flowing mixture of oxygen and nitrogen. 1.2 Methods are provided for testing materials that are structurally self-supporting in the form of vertical bars or sheet up to 10.5 mm thick. These methods are suitable for solid, laminated or cellular materials characterized by an apparent density greater than 15 kg/m3. The methods may also be applicable to some cellular materials having an apparent density of less than 15 kg/m3. A method is provided for testing flexible sheet or film materials while supported vertically. NOTE 1—Although this test method has been found applicable for testing other materials, the precision of the test method has not been determined for these materials, or for specimen geometry’s and test conditions outside those recommended herein. 山纺仪器专业氧指数测定仪生产厂家,详情请查询公司网站:www.chinaqd17.com
环境因素对服装点对点电阻测试结果影响分析
简介:环境因素对服装点对点电阻测试结果影响分析 摘要:静电放电过程中产生的电火花或电磁场在某些特定环境中会造成重大危害,引起社会泛关注。穿戴防静电服是静电防护的重要手段,防静电服面料的点对点电阻是防静电服主要性能指标之一,对该指标的准确测量有助于对服装防护能力的准确认识。本文阐述了面料点对点电阻测试原理,详细讨论了防静电服点对点电阻测试结果的组成,指出测试过程中的影响因素包括环境温湿度、测试台面绝缘性能、仪器周围的电磁环境和操作人员的带电等,其中重点分析了环境温湿度对测试结果的影响,指出环境温湿度是点对点电阻测试过程中的主要影响因素,以期通过对相关因素的控制提高对该项性能指标测试结果的准确程度。 关键词:防静电服;点对点电阻;影响因素
点对点测试仪 A102产品样本 山纺仪器
简介:点对点测试仪用于防静电服点对点电阻的测量,是GB 12014-2009标准规定的防静电服两大专用静电检测仪器之一,另外一种是A101带电电荷量测试仪。点对点测试仪是防静电服生产企业申办生产许可证和劳安认证(LA)的必备检测设备。 一、主要用途 本仪器专用于防静电服点对点电阻的测量,可测量防静电面料的点对点电阻、定制专用电极后,也可用于防静电服的表面电阻率测试,可供防静电服生产企业质量内控、过捡认证使用,也广泛适用于各大国家检测机构和高校研究院所。 二、仪器特征 ●桥式测量电路,测量准确度高,读数方便、准确。 ●便携式结构,体积小重量轻,使用方便。 ●内置定时器,15秒后自动锁定读数。
GB12014防静电服装国家标准
简介:防静电服装国家标准GB12014-2009 中华人民共和国国家标准 GB 12014—2009 代替GB 12014 —1989 防静电服 static protective clothing 前 言 本标准4.1.2、4.1.3、4.2.5、4.2.6、4.2.7、第6章、第7章为强制性,其余为推荐性。 本标准代替GB l2014 -1989《防静电工作服》。 本标准与GB l2014-1989相比主要变化如下: ——增加了静电耗散材料、表面电阻率、点对点电阻的定义; ——增加了讲静电面料外观质量要求; ——增加了防静电面料点对点电阻的技术要求及测试方法; ——增加了防静电面科甲醛含量、 pH值、尺寸变化率、耐水色牢度、透气量、耐干摩色牢度、耐光 色牢度的技术要求和测试方法; ——增加了防静电服的缝制要求; ——增加了防静电服的检验类别;
GB29416-2012 建筑外墙保温系统的防火性能试验方法
简介:前言 GB/T 29416-2012 本标准按照GB/T 1.1-2009给出的规则起草。 本标准编制时参考了BS 8414-1: 2002《建筑外包覆系统的防火性能第1部分:适用于建筑表面非 承重外包覆系统的试验方法》。 本标准由中华人民共和国公安部提出。 本标准由全国消防标准化技术委员会建筑构件耐火性能分技术委员会(SAC/TC 113/SC 8)归口。 本标准负责起草单位:公安部天津消防研究所。 本标准参加起草单位:中国建筑科学研究院、公安部四川消防研究所、北京振利高新技术有限公司、 山东圣泉化工股份有限公司、中国聚氨酯工业协会。
GBT8624-2012 建筑材料及制品燃烧性能分级
简介:GB 8624-2012 建筑材料及制品燃烧性能分级 引 言 GB 8624于1988年首次发布,其后参照西德标准DIN 4102-1:1981《建筑材料和构件的火灾特性 第1部分:建筑材料燃烧性能分级的要求和试验》,对其进行了第1次修订,发布了修订版GB 8624- 1997。作为我国建筑材料燃烧性能的分级准则,GB 8624-1997在评价材料燃烧性能及其分级、指导防 火安全设计、实施消防监督、执行建筑设计防火规范等方面发挥了重要作用。
