资料下载Many cell-based research studies require the counting of cells prior to beginning an experiment. This allows standardization of cell concentration between samples, minimizing error and variation in downstream results. There are several different counting methods and instruments available to accomplish this task, including glass and disposable hemocytometers, flow cytometers, and benchtop counters. This technical note compares the Countess™ Automated Cell Counter to the Beckman Coulter Z1™ Series Coulter Counter® Cell and Particle Counter, examining methodology and performance. The Countess™ method provides comparable performance to the Coulter counter method, while offering the following additional benefits: ••Easier methodology, setup, and maintenance ••Provides cell viability and size data in addition to cell counts ••Actual results are visualized, increasing confidence ••More affordable
Cellntec细胞培养基成分说明
简介:Glycine Ammonium Ascorbic acid L-Alanine Calcium Biotin L-Arginine Chlorine Pantothenate L-Asparagine Copper Choline L-Aspartic acid Iron Folic acid L-Cystine Potassium Myo-inositol L-Cysteine Manganese Niacinamide L-Glutamic acid Magnesium Putrescine L-Glutamine Sodium Pyridoxine L-Histidine Sulfur Riboflavin L-Isoleucine Carbonate Thiamine L-Leucine Nickel Vitamin B12 L-Lysine Silicate L-Methionine Zinc L-Phenylalanine Selenium L-Proline Tin L-Serine Phosphorus L-Threonine Molybdenum L-Tryptophan L-Valine L-Tyrosine
Celltec细胞培养基文献发表清单
简介:从2007年开始,Cellntec上皮细胞培养基的客户适用群越来越多,其发表的文章已经超过了200篇,影响因子在10以上的超过了一半以上,深受广大科研工作者的好评。
Cellntec细胞培养基常见问题解答
简介:问:CELLnTEC培养基的存储温度? 答:CELLnTEC是一个Kit,包含500ml的基础培养基(4ºC,避光保存),一包补充物干粉(-20ºC保存)。当补充物加入基础培养基中,需4ºC避光保存。不能冷冻保存基础培养基或补充培养基,因为这样可能会导致一些蛋白不可逆的凝固。
细胞培养基使用说明书
简介:细胞培养基的成分,适用说明,注意事项,保存条件,运输条件,适用对象,培养基说明,适用组织类型,培养条件,质量控制等详细说明。
Celltec细胞培养基宣传单页
简介:独特祖细胞生长配方; 专用上皮细胞培养基; 适用于增殖或分化培养; 高细胞分离率和最佳细胞形态; 可增长细胞寿命,提高传代次数; 同类产品性能优越; 大量数据文献支持;
