方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Why use FocusClearTM Fluorescence labeling is essential for fluorescence microscopy and confocal microscopic analysis of biological samples. Since many fluorophores are quenched or extracted during routine dehydration procedures, most fluorescence-labeled samples are directly mounted in glycerol-based mounting media for fluorescence and confocal imaging. Under such conditions, a biological structure can be viewed at about 100μm beneath the surface using laser source with wavelength at visible spectrum range. To increase depth of view, one can use two-photon confocal system with infrared laser as light source and viewing structures twice deeper than the conventional confocal microscope. FocusClearTM is a water-soluble clearing agent for increases the transparency of biological tissues.
净水、纯水、软水区别
热膨胀系数仪技术文章
热膨胀分析仪Temperature vs. Time
Carbolite RHF 高温箱式炉
高温粘度计测样
上海欢奥 煤灰熔融性测试
BINDER C170 CO2培养箱
OHAUS Explorer 准微量天平
OHAUS Explorer 分析天平
OHAUS Adventurer AX 分析天平
PIONEER PX系列 准微量天平
OHAUS PIONEER PX系列 分析天平
OHAUS PIONEER PR系列 分析天平
OHAUS Explorer 精密天平
OHAUS Explorer 大称量天平
OHAUS Adventurer AX 精密天平
OHAUS Pioneer PX系列 精密天平
OHAUS Pioneer PR系列 精密天平
