产品名称:人肾上腺髓质素(ADM)ELISA Kit
英文名称:Human adrenomedullin,ADM ELISA Kit
产品类型: ELISA Kit
货号: CSB-E09146h
价格: 3600
规格: 96T
种属: Human
样本类型: serum, plasma, tissue homogenates
检测范围: 0.312 pg/ml-20 pg/ml
灵敏度: 0.078 pg/ml
反应时间: 1-5h
所需样本体积: 50-100ul
检测波长: 450nm
用途: For research use only. Not for diagnostic use.
原理: This assay employs the quantitative sandwich enzyme immunoassay technique. Antibody specific for ADM has been pre-coated onto a microplate. Standards and samples are pipetted into the wells and any AD......+This assay employs the quantitative sandwich enzyme immunoassay technique. Antibody specific for ADM has been pre-coated onto a microplate. Standards and samples are pipetted into the wells and any ADM present is bound by the immobilized antibody. After removing any unbound substances, a biotin-conjugated antibody specific for ADM is added to the wells. After washing, avidin conjugated Horseradish Peroxidase (HRP) is added to the wells. Following a wash to remove any unbound avidin-enzyme reagent, a substrate solution is added to the wells and color develops in proportion to the amount of ADM bound in the initial step. The color development is stopped and the intensity of the color is measured.―特异性: This assay has high sensitivity and excellent specificity for detection of Human ADM. No significant cross-reactivity or interference between Human ADM and analogues was observed.
精密度: Intra-assay Precision (Precision within an assay): CV%<8%
Three samples of known concentration were tested twenty times on one plate to assess.
Inter-assay Precision (Precision between assays): CV%<10%
Three samples of known concentration were tested in twenty assays to assess.
样本搜集及储存: Serum: Use a serum separator tube (SST) and allow samples to clot for two hours at room temperature or overnight at 4°C before centrifugation for 15 minutes at 1000 ×g. Remove serum and assay immediat......+Serum: Use a serum separator tube (SST) and allow samples to clot for two hours at room temperature or overnight at 4°C before centrifugation for 15 minutes at 1000 ×g. Remove serum and assay immediately or aliquot and store samples at -20°C or -80°C. Avoid repeated freeze-thaw cycles.
Plasma: Collect plasma using EDTA, or heparin as an anticoagulant. Centrifuge for 15 minutes at 1000 ×g at 2-8°C within 30 minutes of collection. Assay immediately or aliquot and store samples at -20°C or -80°C. Avoid repeated freeze-thaw cycles.
检测步骤: Bring all reagents and samples to room temperature before use. Centrifuge the sample again after thawing before the assay. It is recommended that all samples and standards be assayed in duplicate. 1......+Bring all reagents and samples to room temperature before use. Centrifuge the sample again after thawing before the assay. It is recommended that all samples and standards be assayed in duplicate.
1. Prepare all reagents, working standards, and samples as directed in the previous sections.
2. Refer to the Assay Layout Sheet to determine the number of wells to be used and put any remaining wells and the desiccant back into the pouch and seal the ziploc, store unused wells at 4°C.
3. Add 100μl of standard and sample per well. Cover with the adhesive strip provided. Incubate for 2 hours at 37°C. A plate layout is provided to record standards and samples assayed.
4. Remove the liquid of each well, don't wash.
5. Add 100μl of Biotin-antibody (1x) to each well. Cover with a new adhesive strip. Incubate for 1 hour at 37°C. (Biotin-antibody (1x) may appear cloudy. Warm up to room temperature and mix gently until solution appears uniform.)
6. Aspirate each well and wash, repeating the process two times for a total of three washes. Wash by filling each well with Wash Buffer (200μl) using a squirt bottle, multi-channel pipette, manifold dispenser, or autowasher, and let it stand for 2 minutes, complete removal of liquid at each step is essential to good performance. After the last wash, remove any remaining wash Buffer by aspirating ordecanting. Invert the plate and blot it against clean paper towels.
7. Add 100μl of HRP-avidin (1x) to each well. Cover the microtiter plate with a new adhesive strip. Incubate for 1 hour at 37°C.
8. Repeat the aspiration/wash process for five times as in step 6.
9. Add 90μl of TMB Substrate to each well. Incubate for 15-30 minutes at 37°C. Protect from light.
10. Add 50μl of Stop Solution to each well, gently tap the plate to ensure thorough mixing.
11. Determine the optical density of each well within 5 minutes, using a microplate reader set to 450 nm. If wavelength correction is available, set to 540 nm or 570 nm. Subtract readings at 540 nm or 570 nm from the readings at 450 nm. This subtraction will correct for optical imperfections in the plate. Readings made directly at 450 nm without correction may be higher and less accurate.
结果计算: Using the professional soft "Curve Expert 1.3" to make a standard curve is recommended, which can be downloaded from our web. Average the duplicate readings for each standard and sample and subtract......+Using the professional soft "Curve Expert 1.3" to make a standard curve is recommended, which can be downloaded from our web.
Average the duplicate readings for each standard and sample and subtract the average zero standard optical density.
Create a standard curve by reducing the data using computer software capable of generating a four parameter logistic (4-PL) curve-fit. As an alternative, construct a standard curve by plotting the mean absorbance for each standard on the x-axis against the concentration on the y-axis and draw a best fit curve through the points on the graph. The data may be linearized by plotting the log of the ADM concentrations versus the log of the O.D. and the best fit line can be determined by regression analysis. This procedure will produce an adequate but less precise fit of the data.
If samples have been diluted, the concentration read from the standard curve must be multiplied by the dilution factor.
产品名称 货号 规格
Dog adrenomedullin,ADM ELISA Kit CSB-E09836c 96T
Bovine adrenomedullin (ADM) ELISA kit CSB-EL001370BO 96T
Fish adrenomedullin (ADM) ELISA kit CSB-EL001370FI 96T
Mouse adrenomedullin,ADM ELISA Kit CSB-E10061m 96T
Rat adrenomedullin,ADM ELISA Kit CSB-E10060r 96T
Rabbit adrenomedullin,ADM ELISA Kit CSB-E09837Rb 96T
Pig adrenomedullin (ADM)ELISA kit CSB-EL001370PI 96T
Monkey adrenomedullin,ADM ELISA Kit CSB-E09838Mo 96T
Chicken adrenomedullin,ADM ELISA Kit CSB-E04843Ch 96T
蛋白
产品名称 规格
Recombinant Bovine ADM(ADM) 1mg
Recombinant Dog ADM(ADM) 1mg
Recombinant Pig ADM(ADM) 1mg
Recombinant Human ADM(ADM) 1mg
Recombinant Rat ADM(Adm) 1mg
上海飞轩生物提供犬胰岛素(INS)ELISA Kit
上海飞轩生物提供猴胰岛素(INS)ELISA Kit
上海飞轩生物提供猪胰岛素(INS)ELISA Kit
上海飞轩生物提供小鼠胰岛素(INS)ELISA Kit
重组人肌球蛋白轻链2(Recombinant Human MYL2)
重组大鼠抵抗素(Rat Resistin)
仓鼠基质金属蛋白酶9/明胶酶B(MMP-9/Gelatinase B)ELISA Kit
Pig C-type lectin domain family 5 member A(CLEC5A)ELISA kit
Mouse C-type lectin domain family 5 member A(CLEC5A)ELISA kit
Human C-type lectin domain family 5 member A(CLEC5A)ELISA kit
牛甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
鸡甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
犬甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
豚鼠甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
猪甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
兔子甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
绵羊甘油醛-3-磷酸脱氢酶(GAPDH)ELISA kit
牛窖蛋白Caveolin-1(CAV1)ELISA kit
猫窖蛋白Caveolin-1(CAV1)ELISA kit
