产品名称: 人转化生长因子β1(TGF-β1)ELISA kit
英文名称: Human Transforming Growth factor β1,TGF-β1 ELISA kit
别名: CED, DPD1, LAP, TGFB, TGFbeta, TGF-beta 1 protein|latency-associated peptide
货号: CSB-E04725h
规格: 96T
种属: Human
待测物名称: transforming growth factor, beta 1
缩写: TGFB1
样本类型: serum, plasma, cell culture supernates
检测范围: 0.8 ng/ml-50 ng/ml
灵敏度: 0.2 ng/ml
反应时间: 1-5h
所需样本体积: 50-100ul
检测波长: 450 nm
用途: For research use only. Not for diagnostic use.
原理 : This assay employs the quantitative sandwich enzyme immunoassay technique. Antibody specific for TGFB1 has been pre-coated onto a microplate. Standards and samples are pipetted into the wells and any TGFB1 present is bound by the immobilized antibody. After removing any unbound substances, a biotin-conjugated antibody specific for TGFB1 is added to the wells. After washing, avidin conjugated Horseradish Peroxidase (HRP) is added to the wells. Following a wash to remove any unbound avidin-enzyme reagent, a substrate solution is added to the wells and color develops in proportion to the amount of TGFB1 bound in the initial step. The color development is stopped and the intensity of the color is measured.
特异性: This assay has high sensitivity and excellent specificity for detection of Human TGFB1. No significant cross-reactivity or interference between Human TGFB1 and analogues was observed.
精密度: Intra-assay Precision (Precision within an assay): CV%<8%
Three samples of known concentration were tested twenty times on one plate to assess.
Inter-assay Precision (Precision between assays): CV%<10%
Three samples of known concentration were tested in twenty assays to assess.
样本搜集及储存: Serum: Use a serum separator tube (SST) and allow samples to clot for two hours at room temperature or overnight at 4°C before centrifugation for 15 minutes at 1000 ×g. Remove serum and assay immediately or aliquot and store samples at -20°C or -80°C. Avoid repeated freeze-thaw cycles.
Plasma: Collect plasma using EDTA, or heparin as an anticoagulant. Centrifuge for 15 minutes at 1000 ×g at 2-8°C within 30 minutes of collection. Assay immediately or aliquot and store samples at -20°C or -80°C. Avoid repeated freeze-thaw cycles.
检测步骤: Bring all reagents and samples to room temperature before use. Centrifuge the sample again after thawing before the assay. It is recommended that all samples and standards be assayed in duplicate.
1. Prepare all reagents, working standards, and samples as directed in the previous sections.
2. Refer to the Assay Layout Sheet to determine the number of wells to be used and put any remaining wells and the desiccant back into the pouch and seal the ziploc, store unused wells at 4°C.
3. Add 100μl of standard and sample per well. Cover with the adhesive strip provided. Incubate for 2 hours at 37°C. A plate layout is provided to record standards and samples assayed.
4. Remove the liquid of each well, don't wash.
5. Add 100μl of Biotin-antibody (1x) to each well. Cover with a new adhesive strip. Incubate for 1 hour at 37°C. (Biotin-antibody (1x) may appear cloudy. Warm up to room temperature and mix gently until solution appears uniform.)
6. Aspirate each well and wash, repeating the process two times for a total of three washes. Wash by filling each well with Wash Buffer (200μl) using a squirt bottle, multi-channel pipette, manifold dispenser, or autowasher, and let it stand for 2 minutes, complete removal of liquid at each step is essential to good performance. After the last wash, remove any remaining wash Buffer by aspirating ordecanting. Invert the plate and blot it against clean paper towels.
7. Add 100μl of HRP-avidin (1x) to each well. Cover the microtiter plate with a new adhesive strip. Incubate for 1 hour at 37°C.
8. Repeat the aspiration/wash process for five times as in step 6.
9. Add 90μl of TMB Substrate to each well. Incubate for 15-30 minutes at 37°C. Protect from light.
10. Add 50μl of Stop Solution to each well, gently tap the plate to ensure thorough mixing.
11. Determine the optical density of each well within 5 minutes, using a microplate reader set to 450 nm. If wavelength correction is available, set to 540 nm or 570 nm. Subtract readings at 540 nm or 570 nm from the readings at 450 nm. This subtraction will correct for optical imperfections in the plate. Readings made directly at 450 nm without correction may be higher and less accurate.
结果计算: Using the professional soft "Curve Expert 1.3" to make a standard curve is recommended, which can be downloaded from our web.
Average the duplicate readings for each standard and sample and subtract the average zero standard optical density.
Create a standard curve by reducing the data using computer software capable of generating a four parameter logistic (4-PL) curve-fit. As an alternative, construct a standard curve by plotting the mean absorbance for each standard on the x-axis against the concentration on the y-axis and draw a best fit curve through the points on the graph. The data may be linearized by plotting the log of the TGFB1 concentrations versus the log of the O.D. and the best fit line can be determined by regression analysis. This procedure will produce an adequate but less precise fit of the data.
If samples have been diluted, the concentration read from the standard curve must be multiplied by the dilution factor.
相关产品:
产品名称 英文名称 货号 规格
绵羊转化生长因子β1(TGFB1)ELISA kit Sheep Transforming growth factor beta-1(TGFB1) ELISA kit CSB-EL023446SH 96T
大鼠转化生长因子β1(TGF-β1)ELISA kit Rat Transforming Growth Factor β1(TGF-β1) ELISA kit CSB-E04727r 96T
鱼转化生长因子β1(TGFB1) ELISA kit Fish transforming growth factor, beta 1 (TGFB1) ELISA kit CSB-EL023446FI 96T
牛转化生长因子β1(TGF-β1)ELISA Kit Bovine transforming growth factor β1,TGF-β1 ELISA Kit CSB-E14208B 96T
猪转化生长因子β1(TGF-β1)ELISA Kit Pig transforming growth factor β1(TGF-β1)ELISA Kit CSB-E06843p 96T
小鼠转化生长因子β1(TGF-β1)ELISA Kit Mouse Transforming Growth factor β1,TGF-β1 ELISA kit CSB-E04726m 96T
Horse Transforming growth factor beta-1(TGFB1) ELISA kit Horse Transforming growth factor beta-1(TGFB1) ELISA kit CSB-EL023446HO 96T
豚鼠转化生长因子β1(TGF-β1)ELISA Kit guinea pig transforming growth factor β1,TGF-β1 ELISA Kit CSB-E06773Gu 96T
犬转移生长因子β1(TGF-β1)ELISA Kit Dog Transforming growth factor β1,TGF-β1 ELISA Kit CSB-E04796c 96T
鸡转化生长因子β1(TGF-β1)ELISA kit Chicken Transforming Growth factor β1,TGF-β1 ELISA kit CSB-E09875Ch 96T
抗体
产品名称 货号 规格
Rabbit anti-human transforming growth factor, beta 1 polyclonal Antibody CSB-PA023446GA01HU 150ul
蛋白
产品名称 货号 规格 蛋白来源
Recombinant Oncorhynchus mykiss Transforming growth factor beta-1(tgfb1) CSB-EP023446OEI 1mg E.coli
Recombinant Oncorhynchus mykiss Transforming growth factor beta-1(tgfb1) CSB-YP023446OEI 1mg Yeast
Recombinant Chlorocebus aethiops Transforming growth factor beta-1(TGFB1) CSB-EP023446DSU 1mg E.coli
Recombinant Chlorocebus aethiops Transforming growth factor beta-1(TGFB1) CSB-YP023446DSU 1mg Yeast
Recombinant Xenopus laevis Transforming growth factor beta-1(tgfb1) CSB-EP023446XBE 1mg E.coli
Recombinant Xenopus laevis Transforming growth factor beta-1(tgfb1) CSB-YP023446XBE 1mg Yeast
Recombinant Horse Transforming growth factor beta-1(TGFB1) CSB-EP023446HO 1mg E.coli
Recombinant Horse Transforming growth factor beta-1(TGFB1) CSB-YP023446HO 1mg Yeast
Recombinant Chicken Transforming growth factor beta-1(TGFB1) CSB-EP023446CH 1mg E.coli
Recombinant Chicken Transforming growth factor beta-1(TGFB1) CSB-YP023446CH 1mg Yeast
Recombinant Pig Transforming growth factor beta-1(TGFB1) CSB-EP023446PI 1mg E.coli
Recombinant Pig Transforming growth factor beta-1(TGFB1) CSB-YP023446PI 1mg Yeast
Recombinant Human Transforming growth factor beta-1(TGFB1) CSB-EP023446HU 1mg E.coli
Recombinant Human Transforming growth factor beta-1(TGFB1) CSB-YP023446HU 1mg Yeast
Recombinant Mouse Transforming growth factor beta-1(Tgfb1) CSB-EP023446MO 1mg E.coli
Recombinant Mouse Transforming growth factor beta-1(Tgfb1) CSB-YP023446MO 1mg Yeast
Recombinant Dog Transforming growth factor beta-1(TGFB1) CSB-EP023446DO 1mg E.coli
Recombinant Dog Transforming growth factor beta-1(TGFB1) CSB-YP023446DO 1mg Yeast
Recombinant Sheep Transforming growth factor beta-1(TGFB1) CSB-EP023446SH 1mg E.coli
Recombinant Sheep Transforming growth factor beta-1(TGFB1) CSB-YP023446SH 1mg Yeast
Recombinant Bovine Transforming growth factor beta-1(TGFB1) CSB-EP023446BO 1mg E.coli
Recombinant Bovine Transforming growth factor beta-1(TGFB1) CSB-YP023446BO 1mg Yeast
Recombinant Rat Transforming growth factor beta-1(Tgfb1) CSB-EP023446RA 1mg E.coli
Recombinant Rat Transforming growth factor beta-1(Tgfb1) CSB-YP023446RA 1mg Yeast
阅读149次
已关注
