名称:炎症负调控因子蛋白抗体
别名:SELENOS; AD-015; ADO15; MGC104346; MGC2553; SBBI8; SEPS1; VCP-interacting membrane; SELS_HUMAN; Selenoprotein S; SelS; VCP-interacting membrane protein; selenoprotein S; SEPS 1; SELS; VI确MP.
浓度:1mg/1ml
规格:0.1ml/100μg 0.2ml/200μg
抗体来源:Rabbit
克隆类型:polyclonal
交叉反应:Human, Mouse, Rat, Dog, Cow
产品类型:一抗
研究领域:免疫学 信号转导
蛋白分子量:predicted molecular weight: 21kDa
性状:Lyophilized or Liquid
免疫原:KLH conjugated synthetic peptide derived from human selenoprotein S
亚型:IgG
纯化方法:affinity purified by Protein A
储存液:0.01M PBS, pH 7.4 with 10 mg/ml BSA and 0.1% Sodium azide
产品应用:WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件:Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
产品介绍:This gene encodes a selenoprotein, which contains a selenocysteine (Sec) residue at its active site. The selenocysteine is encoded by the UGA codon that normally signals translation termination. The 3' UTR of selenoprotein genes have a common stem-loop structure, the sec insertion sequence (SECIS), that is necessary for the recognition of UGA as a Sec codon rather than as a stop signal. Studies suggest that this protein may regulate cytokine production, and thus play a key role in the control of the inflammatory response. Two alternatively spliced transcript variants encoding the same protein have been found for this gene. [provided by RefSeq, Jul 2008].
Function : Involved in the degradation process of misfolded endoplasmic reticulum (ER) luminal proteins. Participates in the transfer of misfolded proteins from the ER to the cytosol, where they are destroyed by the proteasome in a ubiquitin-dependent manner. Probably acts by serving as a linker between DERL1, which mediates the retrotranslocation of misfolded proteins into the cytosol, and the ATPase complex VCP, which mediates the translocation and ubiquitination.
Subunit : Interacts with DERL1 and VCP, suggesting that it forms a membrane complex with DERL1 that serves as a receptor for VCP.
Subcellular Location : Endoplasmic reticulum membrane; Single-pass membrane protein. Cytoplasm (By similarity).
Similarity : Belongs to the selenoprotein S family.
Database links : UniProtKB/Swiss-Prot: Q9BQE4.3
炎症负调控因子蛋白-Tanis蛋白在肝脏、脂肪和骨骼肌等组织都有其基因表达,可能作为血清淀粉样蛋白A受体参与糖代谢,并与胰岛素抵抗、Ⅱ型糖尿病的发生与发展密切相关。Tanis在胰岛素抵抗、Ⅱ型糖尿病和代谢综合征动物模型的肝脏中表达水平与血糖及胰岛素浓度呈负相关,与血浆甘油三酯浓度呈正相关。Tanis的基因表达在禁食24 h后的糖尿病动物模型中显著增加,说明受葡萄糖调节。从目前的研究资料看,Tanis有可能成为治疗胰岛素抵抗、Ⅱ型糖尿病的新靶点而受到重视。
最新Elisa实验稀释问题解析方案
Elisa试剂盒实验类型
揭示小鼠ELISA试剂盒感染期间T细胞耗竭的分子根源
人ELISA试剂盒与抗蠕虫药
人伤寒抗体(typhoidAb)检测试剂盒
人血管内皮生长因子-A(VEGF-A)检测试剂盒
人血管内皮生长因子-D(VEGFD)检测试剂盒
人血管内皮生长因子受体1(VEGFR1)检测试剂盒
人血管内皮细胞蛋白C受体(PROCR)检测试剂盒
人血管内皮细胞生长因子C(VEGFC)检测试剂盒
人血管生成素蛋白4(ANG-4)检测试剂盒
人血管生成素样蛋白4(ANGPTL4)检测试剂盒
人血管细胞生长因子(VCAM-1)检测试剂盒
人血清可溶性OX40配体(SOX40L)检测试剂盒
人血吸虫IgM(SchIgM)检测试剂盒
人血小板球蛋白β血栓环蛋白(β-TG)检测试剂盒
人血小板衍生生长因子BB(PDGFBB)检测试剂盒
人血小板因子4(PF4)检测试剂盒
