丝氨酸蛋白酶抑制剂B10抗体
别名:Bomapin; PI10; Protease inhibitor 10; Protease inhibitor 10 (ovalbumin type bomapin); Serpin B10; Serpin peptidase inhibitor clade B (ovalbumin) member 10; SPB10_HUMAN.
浓度:1mg/1ml
规格:0.2ml/200μg
抗体来源:Rabbit
克隆类型:polyclonal
交叉反应:Human
产品类型:一抗
研究领域:心血管 细胞生物
蛋白分子量:predicted molecular weight: 45kDa
性状:Lyophilized or Liquid
免疫原:KLH conjugated synthetic peptide derived from human SERPINB10
亚型:IgG
纯化方法:affinity purified by Protein A
储存液:Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
产品应用:WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 IF=1:50-200
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件:Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
产品介绍:SERPINB10 is a serine proteinase inhibitor of the ovalbumin like B clade of serpins. It was first discovered in human bone marrow in a search for serpins similar to SerpinB6. SERPINB10 was identified in lymphocytes, and was elevated in chronic myeloid leukemia and chronic myelomonocytic leukemia cells. The monocytic cell lines THP-1 and AML-193 also showed elevated SERPINB10 expression.
Function : Protease inhibitor that may play a role in the regulation of protease activities during hematopoiesis and apoptosis induced by TNF. May regulate protease activities in the cytoplasm and in the nucleus.
Subcellular Location : Nucleus. Cytoplasm.
Tissue Specificity : Expressed specifically in the bone marrow.
Similarity : Belongs to the serpin family. Ov-serpin subfamily.
Database links : UniProtKB/Swiss-Prot: P48595.1
最新Elisa实验稀释问题解析方案
Elisa试剂盒实验类型
揭示小鼠ELISA试剂盒感染期间T细胞耗竭的分子根源
人ELISA试剂盒与抗蠕虫药
人伤寒抗体(typhoidAb)检测试剂盒
人血管内皮生长因子-A(VEGF-A)检测试剂盒
人血管内皮生长因子-D(VEGFD)检测试剂盒
人血管内皮生长因子受体1(VEGFR1)检测试剂盒
人血管内皮细胞蛋白C受体(PROCR)检测试剂盒
人血管内皮细胞生长因子C(VEGFC)检测试剂盒
人血管生成素蛋白4(ANG-4)检测试剂盒
人血管生成素样蛋白4(ANGPTL4)检测试剂盒
人血管细胞生长因子(VCAM-1)检测试剂盒
人血清可溶性OX40配体(SOX40L)检测试剂盒
人血吸虫IgM(SchIgM)检测试剂盒
人血小板球蛋白β血栓环蛋白(β-TG)检测试剂盒
人血小板衍生生长因子BB(PDGFBB)检测试剂盒
人血小板因子4(PF4)检测试剂盒
