ATP6V0D2蛋白抗体供应
ATP6V0D2蛋白抗体供应
『别名』ATP6D2; ATPase H+ transporting lysosomal 38kDa V0 subunit D; ATPase H+ transporting lysosomal 38kDa V0 subunit D isoform 2; ATPase H+ transporting lysosomal 38kDa V0 subunit D2; FLJ38708; V ATPase subunit d 2; Vacuolar ATP synthase subunit d 2; Vacuolar proton pump subunit d 2; VMA 6; VMA6; VA0D2_HUMAN.
『浓度』1mg/1ml
『规格』0.2ml/200μg
『抗体来源』Rabbit
『克隆类型』polyclonal
『交叉反应』Human, Mouse, Rat, Dog, Pig, Sheep
『产品类型』一抗
『研究领域』ATP6V0D2蛋白抗体供应 肿瘤 细胞生物 信号转导 新陈代谢
『蛋白分子量』predicted molecular weight: 40kDa
『性状』Lyophilized or Liquid
『免疫原』KLH conjugated synthetic peptide derived from human ATP6V0D2/V-ATPase D2
『亚型』IgG
『纯化方法』affinity purified by Protein A
『储存液』Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
『产品应用』WB=1:100-500  ELISA=1:500-1000  IP=1:20-100  IHC-P=1:100-500  IHC-F=1:100-500  ICC=1:100-500  IF=1:100-500
(石蜡切片需做抗原修复)
 not yet tested in other applications.
 optimal dilutions/concentrations should be determined by the end user.
『保存条件』Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note  This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
『产品介绍』Vacuolar-type H+-ATPase (V-ATPase) is a multisubunit enzyme responsible for acidification of eukaryotic intracellular organelles. V-ATPases pump protons against an electrochemical gradient, while F-ATPases reverse the process, thereby synthesizing ATP. A peripheral V1 domain, which is responsible for ATP hydrolysis, and a integral V0 domain, which is responsible for proton translocation, compose V-ATPase. Nine subunits (A–H) make up the V1 domain and five subunits (a, d, c, c' and c") make up the V0 domain. Like F-ATPase, V-ATPase most likely operates through a rotary mechanism. V-ATPase D2 is a 350 amino acid protein that is expressed in kidney, lung and osteoclast. V-ATPase D2 has been implicated as a regulator of urine acidification, osteoclast fusion and bone formation. Furthermore, V-ATPase D2 has been identified as a dendritic cell marker.
Function : Subunit of the integral membrane V0 complex of vacuolar ATPase. Vacuolar ATPase is responsible for acidifying a variety of intracellular compartments in eukaryotic cells, thus providing most of the energy required for transport processes in the vacuolar system. May play a role in coupling of proton transport and ATP hydrolysis (By similarity).
Subunit : V-ATPase is a heteromultimeric enzyme composed of a peripheral catalytic V1 complex (components A to H) attached to an integral membrane V0 proton pore complex (components: a, c, c', c'' and d).
Subcellular Location :ATP6V0D2蛋白抗体供应 Apical plasma membrane.
Tissue Specificity : Kidney, osteoclast and lung.
Similarity : Belongs to the V-ATPase V0D/AC39 subunit family.
Database links : UniProtKB/Swiss-Prot: Q8N8Y2.1
阅读133次
最新动态
当前位置: 上海基免 动态 ATP6V0D2蛋白抗体供应
