英国BIBBY旗下老牌JENWAY, 推出高级双光束分光光光度计6850。这是JENWAY最先引入的带有可变光谱带宽的双光束分光光度计。
新型6850的可变的光谱带宽为0.5nm, 1nm, 2nm, 4nm 及 5nm,符合欧洲药典要求。高稳定性的光学器件和两个探测器能够以最优的测量精确度同时测量样品和对照样品。6850型的测量模式包括:光度学,浓度,多波长,光谱扫描,动力学,定量,DNA/RNA和蛋白质分析。
集成的用户界面, 可让您实现对仪器的完美控制,无需另外购PC; 不过, 作为完美仪器的一部分,标准配件中也包括了Jenway Prism PC软件,并提供附加的功能用于预置DNA/RNA和protein分析方法,同时还包含各种测量后工具,无限制的结果存储和简易的数据输出。
6850是质量控制的理想工具,适于普通研究、药物学,材料学,生物化学和临床实验室等各方面应用。同时有各种不同的附件可供选择。
JENWAY 其它分光光度计视频如下: (在优酷网也可找到 www.youku.com )
链接:http://v.youku.com/v_show/id_XNzMwNDM1NDIw.html
Jenway's new top-of-the-range 6850 spectrophotometer
The 6850 UV/visible spectrophotometer is Jenway's first double-beam instrument with a variable spectral bandwidth - of 5nm down to 0.5nm. This new instrument has highly stable optics and is particularly well-suited for use in laboratories where compliance to multiple regulatory agencies is required.
The double beam optics and two detectors measure the sample and reference simultaneously for optimum measurement accuracy and stability over long periods of time. The 6850 has a variable spectral bandwidth of 0.5nm, 1nm, 2nm, 4nm and 5nm, giving flexibility whilst ensuring compliance to European Pharmacopeia requirements. The narrow spectral bandwidth also ensures improved peak resolution.
An integrated user interface provides full control of the instrument so there is no need to buy a PC to run the spectrophotometer. However, Jenway Prism PC control software is included as standard, introducing functionality such as greater data storage, additional post-measurement tools and pre-loaded DNA and protein methods.
Designed for quality control, research and routine applications in life science, materials science and the pharmaceutical industry, the Jenway 6850 spectrophotometer offers multiple measurement modes for photometrics, concentration, multi-wavelength, spectrum scanning, kinetics, quantitation, DNA/RNA and protein analysis. An extensive range of accessories is also available.
关于语特 和 英国Bibby / 德国ART / 德国CAT ( http://bibbyyt.instrument.com.cn. 电话/传真: 020 2802 3589; 电邮: GZ_YT8@163.com)
广州语特仪器科技有限公司专注于搅拌器/分散乳化机等实验室样品制备等通用仪器, 熔点仪/光度计等分析仪器,以及PCR等生命科学仪器。 作为英国比比(Bibby )在中国南方的首代,广东,广西,四川,重庆,云南,海南,贵州和西藏是我司的服务范围。语特公司也是德国ART, 德国CAT 在中国的首代。
英国BIBBY 成立于上个世纪50年代,作为英国最大的实验室科学仪器仪器生产商,世界上拥有最广泛产品系列的实验室仪器制造商之一, 其向全球提供的品牌产品以高品质和高操作性能而著称. 旗下有4个子品牌:Stuart,Techne,Jenway,Electrothermal.
l Stuart: 专注于样品前处理等通用实验室仪器,包括: 熔点仪, 菌落计数器, 搅拌器, 混匀器,摇床, 纯水蒸馏器系列;
l Techne: 专注于分子生物学研究设备(基因扩增仪和杂交箱), 以及温度控制产品系列(包括水浴和干浴) ;
l Jenway: 是紫外/分光光度计, 火焰光度计,色度计等分析仪器的专家;
l Electrothermal: 作为有70多年历史的BIBBY的新成员,全球领先的科学仪器提供者,提供电加热套,平行反应设备, 凯氏定氮设备, 电子本生灯系列。其平行反应设备是全球市场领导者。
德国ART 成立于上个世纪,是德国乃至全球最专业的分散乳化专家。 其顶级分散乳化产品从实验室仪器,中试产品到工业设备, 分散头种类极多,可满足客户各类需求;应用领域覆盖了化工,化妆品,制药,食品,环保等各大领域。
德国CAT 成立于上个世纪50年代,是德国样品制备仪器方面的专家之一。其搅拌器,从手持式,教学用,到科研通用型,高粘度型,应有尽有,是CAT的代表产品线; 而今又由普通电子马达走向无刷马达, 引领着搅拌器的研发潮流。
2017年中秋国庆放假通知
光泽细腻的保湿霜的制作 - 使用德国MICCRA纳米级中试分散乳化机试样
MC.ART 全自动分散机现正接受试样! - 附广州研究所试样情况
实验室样品浓缩的“暖男”—英国Stuart氮吹仪
