-- Omni 的高效节能与使用方便性
在英国威尔士Cardiff 大学化学院,研究学者们用Bibby 旗下的 Electrothermal 品牌 的 Omni 平行反应工作站作了一个测试。结果表明:与其它类似仪器相比,该平行反应工作站表现卓越。整个过程在节能和热传输方面都作了时时测量, 充分证明了其低能耗及温度控制的精确性。
测试过程中, 反应工作站被设定参数为800 rpm 及65°C,要求监控24小时。 工作站只加热了30分钟即达到了设定温度。一旦达到设定温度后, 温度探头的温度与盘面温度几乎一致,说明了加热盘与样品之间的热传输的高效节能,热损失非常少。
24小时后测量了其能耗。Omni平行反应工作站只使用了1.5 Kwh, 而其它平行反应工作站需耗能3.6 Kwh ,能耗降低了一倍不止。
“Omni平行反应工作站是一个非常优秀的工作站,”Cardiff 大学催化组博士Scott Board 如是说。 “它无论是在节能方面还是热传输能力方面均优于我们以前其它品牌的仪器,从而也让我们的日常工作更加有效率。 工作站上部的冷凝模块, 使多点反应时,工作站能保持更加洁净。”
Electrothermal品牌对平行反应有70多年的丰富经验。Omni平行反应工作站,设计简单,加热与搅拌功能精准, 节能低耗。几个工作程序同时工作,是平行反应的最佳之选。
Cardiff University tests show Electrothermal Omni
Tests working with Electrothermal's Omni reaction stations, conducted by researchers in the School of chemistry at Cardiff University in Wales, have shown the instrument's enhanced performance compared to other available systems. Energy consumption and thermal transfer were both measured during the course of testing, and illustrated the station's low energy usage and tight temperature control.
During testing, the reaction station was set to 65°C at 800rpm and monitored for 24 hours. It took just 30 minutes to heat up to the required temperature. Once achieved, there was little variation between vial temperature and sensor temperature, demonstrating efficient rates of thermal transfer between the plate and the sample.
When energy consumption over the 24-hour period was measured, the Omni reaction station's energy usage of 1.5 Kwh was less than half the 3.6 Kwh used by another station tested.
"The Omni reaction station is a very nice piece of kit to work with," commented Scott Board, PhD student in the catalysis group at Cardiff University. "It outperforms our previous equipment both in terms of energy usage and the thermal ability of the machine, and also makes day to day use much more efficient. The use of the condensing block at the top really clears up the workstation, which has the potential to become quite cluttered when multiple reactions are taking place."
Omni reaction stations are designed with ease-of-use in mind, and combine accurate heating and stirring functions with low energy consumption. The stations can run multiple procedures simultaneously, making them ideal for parallel synthesis reactions.
关于语特 和 英国Bibby / 德国ART / 德国CAT ( www.youtoolinstru.cn. 电话/传真: 020 8252 0656; 电邮: info@youtoolinstru.cn)
广州语特仪器科技有限公司专注于搅拌器/分散乳化机等实验室样品制备等通用仪器, 熔点仪/光度计等分析仪器,以及PCR等生命科学仪器。 作为英国比比(Bibby )在中国南方的首代,广东,广西,四川,重庆,云南,海南,贵州和西藏是我司的服务范围。语特公司也是德国ART, 德国CAT 在中国的首代。
英国BIBBY 成立于上个世纪50年代,作为英国最大的实验室科学仪器仪器生产商,世界上拥有最广泛产品系列的实验室仪器制造商之一, 其向全球提供的品牌产品以高品质和高操作性能而著称. 旗下有4个子品牌:Stuart,Techne,Jenway,Electrothermal.
Stuart: 专注于样品前处理等通用实验室仪器,包括: 熔点仪, 菌落计数器, 搅拌器, 混匀器,摇床, 纯水蒸馏器系列;
Techne: 专注于分子生物学研究设备(基因扩增仪和杂交箱), 以及温度控制产品系列(包括水浴和干浴) ;
Jenway: 是紫外/分光光度计, 火焰光度计,色度计等分析仪器的专家;
Electrothermal: 作为有70多年历史的BIBBY的新成员,全球领先的科学仪器提供者,提供电加热套,平行反应设备, 凯氏定氮设备, 电子本生灯系列。其平行反应设备是全球市场领导者。
德国ART 成立于上个世纪,是德国乃至全球最专业的分散乳化专家。 其顶级分散乳化产品从实验室仪器,中试产品到工业设备, 分散头种类极多,可满足客户各类需求;应用领域覆盖了化工,化妆品,制药,食品,环保等各大领域。
德国CAT 成立于上个世纪50年代,是德国样品制备仪器方面的专家之一。其搅拌器,从手持式,教学用,到科研通用型,高粘度型,应有尽有,是CAT的代表产品线; 而今又由普通电子马达走向无刷马达, 引领着搅拌器的研发潮流。
瑞士GERBER 盖尔博仪器公司始于1892,至今已有123年的历史。 其总部位于以精准闻名全球的瑞士,GERBER 仪器公司也以精准而闻名于食品仪器行业,一百多年来致力于为乳品及至食品行业提供种类丰富、高精度、高可靠性的仪器,其产品包括:冰点仪、菌落计数器、奶酪专用PH 计、离心机等。
2017年中秋国庆放假通知
光泽细腻的保湿霜的制作 - 使用德国MICCRA纳米级中试分散乳化机试样
MC.ART 全自动分散机现正接受试样! - 附广州研究所试样情况
实验室样品浓缩的“暖男”—英国Stuart氮吹仪
