Rabbit Anti-Snail 1 antibody
Catalog Number :RS-01371R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent ) Background: The zinc finger transcription factor 'SNAIL' was first identified in Drosophila and, along with 'twist', a basic helix-loop-helix transcription factor, is indispensable for mesoderm formation. SNAIL is a repressor of mouse E-cadherin transcription, with expression of SNAIL inversely correlated with expression of E-cadherin. Abnormal expression of SNAIL could underlie the tumorigenic conversion of epithelia associated with loss of E-cadherin expression through screening mouse and human cell lines and by in situ hybridization of primary human tumors undergoing malignant progression.
Function:
Involved in the epithelial to mesenchymal transition (EMT) and formation and maintenance of embryonic mesoderm. Binds to 3 E-boxes of the E-cadherin gene promoter and represses its transcription.
Specificity : Anti- Snail 1 is a rabbit polyclonal antibody
specific for Snail 1 of human,rat,mouse
– use for western blotting,elisa,immunoprecipitation and immunohistochemistry
– Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG
– mol wt:29kDa
Application :
– WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
SOD做预实验时,有几种方法?
组织样本是怎么收集的?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
