eBioscience提供多种荧光标记供选择: | ||||
生产商 目录号 产品名称 试剂盒组分 规格 目录价*eBioscience 85-88-8005-72 Annexin V-FITC Apoptosis Detection Kit Annexin V FITC PI 10X Binding Buffer 50 tests ¥1,548 85-88-8005-74 200 tests ¥4,740 85-88-8006-72 Annexin V-eFluor® 450 Apoptosis Detection Kit Annexin V eFluor® 450 7-AAD 10X Binding Buffer 50 tests ¥2,148 85-88-8006-74 200 tests ¥3,828 85-88-8007-72 Annexin V-APC Apoptosis Detection Kit Annexin V APC PI 10X Binding Buffer 50 tests ¥1,788 85-88-8007-74 200 tests ¥5,280 85-88-8102-72 Annexin V Apoptosis Detection Kit PE Annexin V PE 7-AAD 10X Binding Buffer 50 tests ¥1,548 85-88-8102-74 200 tests ¥4,788 85-88-8008-72 Annexin V PerCP-eFluor® 710 Apoptosis Detection Kit Annexin V PerCP-eFluor® 710 10X Binding Buffer 50 tests ¥2,340 85-88-8008-74 200 tests ¥4,200 85-88-8103-72 Annexin V Apoptosis Detection Kit PE-Cy7 Annexin V PE-Cy7 10X Binding Buffer 50 tests ¥2,148 85-88-8103-74 200 tests ¥4,788 | ||||
*:折后价请联系联科销售人员 | ||||
更多Annexin V试剂: | ||||
产品名称 应用 产品编号 Human anti-Annexin V Platinum ELISA ELISA BMS247* Human Annexin V Platinum ELISA ELISA BMS252* Annexin V-Biotin Apoptosis Detection Kit FC BMS500BT* Annexin V-FITC Apoptosis Detection Kit FC BMS500FICE* Annexin V-FITC Apoptosis Detection Kit FC BMS500FI* Annexin V-APC Recombinant Protein FC BMS306APC* Annexin V-Biotin Recombinant Protein FC BMS306BT* Annexin V-FITC Recombinant Protein FC BMS306FI* Annexin V-Phycoerythrin (PE) Recombinant Protein FC BMS306PE* Annexin V Unlabeled Recombinant Protein FC BMS306* Anti-human Annexin V ELISA BMS1031* anti-human Annexin V/Biotin FC BMS147BT* anti-human Annexin V/FITC FC BMS147FI* anti-human Annexin V FC, ELISA, WB BMS147* Binding Buffer for Annexin V FC BMS500BB* | ||||
搭配可固定的细胞活力染料使用,兼容更多检测(如胞膜和胞内指标的同时检测),具体方法请参见: | ||||
Fixable Viability Dye可固定的细胞活力染料: | ||||
产品名称 激发发射光 产品目录号 Fixable Viability Dye eFluor® 506 Violet / 506 nm 65-0866 Fixable Viability Dye eFluor® 520 Blue / 520 nm 65-0867 Fixable Viability Dye eFluor® 660 Red / 660 nm 65-0864 Fixable Viability Dye eFluor® 780 Red / 780 nm 65-0865 | ||||
阅读原文:http://www.liankebio.com/ProductCenterShow/articleID/2014060026.html
小鼠G-CSF检测试剂盒SunnyELISA新品推荐
小鼠C-Reactive Protein/CRP 检测试剂盒SunnyELISA新品推荐
Human Transferrin/TF检测试剂盒SunnyELISA新品推荐
Human SCF检测试剂盒SunnyELISA新品推荐
